F-Sport SwayBars again...
Old 05-29-08, 10:54 AM
blk250
blk250's Avatar
Default F-Sport SwayBars again...
the rear F-Sport shape is different than the stock, and of course both of them are heavier than the stock ones
Old 05-29-08, 10:56 AM
blk250
blk250's Avatar
and the front
Old 05-29-08, 10:57 AM
blk250
blk250's Avatar
close up of the front
Old 05-29-08, 11:07 AM
APBT4Me
APBT4Me's Avatar
they're both heavier than stock? that is strange known sway manufacturers like hotchkis usually use stronger metal that is also lighter. weight is something you definately want to remove from these porky vehicles where ever possible...that is if you're interested in performance.
Old 05-29-08, 11:55 AM
blk250
blk250's Avatar
yeah, the rear is noticeable, and the front is slightly heavier.
Old 05-29-08, 12:12 PM
ba-b4
ba-b4's Avatar
Yeah the sway's and chassis brace are heavier than the stock parts they replace but not by all that much. I don't think there's much to worry about when the f parts are about 5 to 10lbs over the stock ones when you already have a 3500lb car with over 300hp. Unless you're one of those who are constantly trying to get the lowest drag numbers it's pretty much nothing compared to the kind of improvement you get on handling.
Old 05-29-08, 12:27 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
When upgrading Sways bars from OEM.. 99% of the time they are heavier...
They are bigger, stiffer and usually stronger than OEM..
I ran Hotchkis on my IS300 and they were much heavier than stock..
But it greatly helped in body roll..
It also depends if in production if they are using hollow chrome molly steel, hollow high carbon steel.. or solid bars all together...
These F-Sport Sways are MOST LIKELY hollow just like the Hotchkis...
BTW - does anyone have pics of the Hotchkis to compare???
Joe Z
Old 06-02-08, 10:41 PM
blk_is300
blk_is300's Avatar
Can you post a review of these sway bars after installed? I really want to know the improvements!!
Old 06-03-08, 02:18 PM
carchitect
carchitect's Avatar
Fsport front sway bar is hollow just like the OEM sway bar (both of them). The rear Fsport sway bar is solid and both of them are larger than the OEM one.
BTW, did anyone ever know that the 250 rwd and 350 use different sway bars? You could sell the 350 sway bars to a 250 rwd owner.
Old 06-03-08, 02:59 PM
ba-b4
ba-b4's Avatar
From the f-sport website it says the Fsways are a 151.5% improvement over stock in rigidity.. whereas it'll only be a 43% improvement over stock rigidity in the 250rwd.. wouldn't that mean the stock 250rwd would have stiffer stock rear sways than the 350? It doesn't make sense but that's what the f-sport.com site says. Maybe it should be the other way around... 250 owners can sell their rear sways to 350 owners..
Old 06-03-08, 03:06 PM
iSuxeL
iSuxeL's Avatar
I'll keep that in mind when I get my Hotchkis!
Old 06-08-08, 11:07 AM
Byprodrive
Byprodrive's Avatar
Hollow bar in front & solid bar in rear should help balance front to rear weight balance ratio so additional weight that low in the chassis in rear can enhance handling not to mention traction.
I will sell my IS350 swaybars. SoCal pickup only
Old 06-08-08, 05:21 PM
Duckiez
Duckiez's Avatar
wat is the size (mm) of the oem sway bar and wat is the size of the f-sport??
Old 06-08-08, 05:37 PM
darkdream
darkdream's Avatar
www.fsport.com they have listed how much stiffer they are
Old 06-17-08, 02:05 PM
ffpowerLN
ffpowerLN's Avatar
Mine just got in today at Carson Toyota, will go pick them up later and have them installed on Sunday.
Stay tuned...
Quick Reply: F-Sport SwayBars again...
