Calling all HKS hipermax LS/LS+ coilover owners****
To lower your car you must twist the shock body to where it looks like the entire strut is getting longer (showing more thread). I know this because a few friends and I recently put a set of HKS Hypermax III's on my girlfriends Honda Fit. At first we were a little confused, until we realized that the entire shock body twists. Its a pain in the @ss to adjust. You put the suspention together, put wheels on, put car on the ground, check your height, then reverse the process if its not low enough. We did it like 3 or 4 times to the Fit to finally get all sides even and at the proper height. Hope this helps you out, bro!
Adjust the shock body up (clockwize) to lower. The teaded part of the shock will start to come out the bottom.
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
you should be able to adjust the height by unbolting the part that is bolted to the lca and just turn it so it looks like its going up. and like NEO said the treaded part should start to show at the bottom of the shock body. hope this helps.
-john
-john
here is a pic for reference..
![](https://www.clublexus.com/forums/attachments/2gen-gs430-400-300-classifieds-98-05/115306d1196755370-brand-new-hks-hipermax-ls-coilovers-for-sale-img_0023.jpg)
If you notice like any coilover you have the spring perch collar and then you have the lock collar underneath(Purple).If you notice the purple collars are on a tube that is threaded to the shock body..thats the tube that gets adjusted and thats what Im trying to figure out..
4rcedfed (07-07-19)
i really dont think they are. most full tap coilvoers have that third collar unless its those types where they adjust the shock length inside the tube like this...which sounds like what Neo300 is explaining....
![](http://www.euro-revolution.net/zentyou.jpg)
but most of them, and most(if not all?) HKS full taps are like this
![](http://www.harumichi-room.com/profile/racingspecdamper.JPG)
![](https://image.blog.livedoor.jp/syun4885/imgs/6/d/6d2ce000.jpg)
Okay I am in the process of scanning the manual I have for my set. I had promised Johnee78 a while back and had problems with the scanner. Now there is one snag... It is all in Japanese so we may need to ask Coco-Bun if he or someone else can translate... I am going to try and attach... OOPS. Sorry folks no can do scanned PDF file is 3 MB. I can e-mail to anyone that wants it or I am open to suggestions..
Johnee78 sent PM
Drew
Johnee78 sent PM
Drew
4rcedfed (07-07-19)
