Air suspension installed! New Stance!
Old 06-22-08, 11:29 AM
  #91
handoverfi
handoverfi's Avatar
how much for a decent system to lift it up and down? i mean something that takes the LEAST amount of space in my trunk? im kinda curious!!
Old 06-22-08, 08:19 PM
  #92
xxlbeerZ
xxlbeerZ's Avatar
Originally Posted by UniAirSusp
UAS on CS v.2
Generally speaking you to get the really low drop take the OEM spring plate, cut off the bump stop cup in the front and it will drop down very good. For the rear, you can trim up the lip on the cone section on the Oem rear mount to get the lower drop.
The main advantage to the coilover setup is that you can tune in what you like for your suspension ride.
We are working on doing a solid one-peice rear bracket kit but, it hasn't been done yet.
Is there any cutting or welding necessary to get a stance like the above?
Old 06-22-08, 08:28 PM
  #93
skperformance
skperformance's Avatar
I have the easy street controller also and it works nice.
You can buy just the controller then wire your own set up to valves or have a full setup with the aluminum valve manifold which is a very nice system .
Mine shows all 4 corners pressures and the tank pressure , and car voltage on the screen . I added silencers which slow down the rate of drop and make it quiet . Do NOT add these they will allow WATER to stay in the lines and not purge out (I live in Canada with winter, get the point) .
Always add a water trap and purge once a week.
Easy street is making a new controller which is wireless also.
There is another company making a very interesting set up which has height adjuster so it is always the right height and level no matter how much weight is in the car.
Good luck.
Old 06-23-08, 11:00 AM
  #94
VIPNiSS
VIPNiSS's Avatar
can someone tell me how much i should expect spending for an air setup?
Old 06-25-08, 10:01 PM
  #95
skperformance
What car , what do you want it to do for your car ,look low or drive nice.
Who is installing it ?
Minimum is about $3000 and up to $7000 with all sorts of crazy add ons.
Old 06-25-08, 10:51 PM
  #96
chrispy
chrispy's Avatar
This thread is breaking my heart. Just pulled the bags off my wreck today.
Old 06-26-08, 09:45 AM
  #97
sakataj
sakataj's Avatar
looks good man
Old 06-26-08, 10:00 AM
  #98
GSteg
GSteg's Avatar
Originally Posted by sakataj
looks good man
I think the word you're looking for is "looked"
Old 06-26-08, 10:02 AM
  #99
4ntvings
4ntvings's Avatar
you didnt have to push the knife in deeper! LOL
Old 06-26-08, 10:06 AM
  #100
GS3Tek
GS3Tek's Avatar
Yeah, kick him while he's down why don't you?????
It will look good again in his next GS
Old 06-26-08, 10:20 AM
  #101
97-SC300
97-SC300's Avatar
Yor GS is insane.... soooo clean.
Old 06-26-08, 10:27 AM
  #102
Phamboogie
Phamboogie's Avatar
i die a little inside every time i see your car before and after
sungzilla
12-03-14 10:22 AM
LostS0ck
CL of Hawaii
10-23-12 02:45 AM
bdan
VIP Style
15
01-28-12 09:31 PM
GS300Rich
Suspension and Brakes
11-09-08 09:06 AM
Quick Reply: Air suspension installed! New Stance!
