Air suspension installed! New Stance!
Old 06-03-08, 12:02 AM
chrispy
chrispy's Avatar
Default Air suspension installed! New Stance!
I've been piecing together air suspension components for the last few months and I finally installed it this weekend. I'm using Universal Air Suspension bags on OEM struts with the Easy Street Autopilot digital controller. I love this setup! It actually rides nicer than my Tein CS with enough air in the bags. But I like to ride low so it's a bit bumpy.
I mounted the controller into the ashtray. It's a great fit.
The best thing about the Autopilot is that it memorizes your ride height. There's no guessing trying to find the settings you like. This helps consistent tire wear too.
The trunk setup is messy right now with wiring everywhere but I'll clean it up. It was very easy to install with straightforward instructions from Easy Street. The valve manifolds clean up a lot of the plumbing since the fill and dump valves are all in the same place.
Onto pics of the new stance! I need to make a custom piece to get the rear lower but I like how it sits right now.
Thank you to xknowonex and 4ntvings for the pics from Jay's meet.
Special thanks to ShaneC and V8 Aristo for answering my many questions about the install.
Old 06-03-08, 12:04 AM
garbage85
garbage85's Avatar
beautiful man, love the scaras
Old 06-03-08, 12:10 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Looks great
Old 06-03-08, 12:29 AM
GSteg
GSteg's Avatar
Dude...the two air compressors look just like the one I have to pump tires. I wouldn't be surprised if they're practically the same
Old 06-03-08, 12:30 AM
TomLee
TomLee's Avatar
nice ride, im so bummed i missed jays. you going to the luau?
Old 06-03-08, 12:33 AM
chrispy
chrispy's Avatar
Thanks guys.
I can use them to pump up my tires too! I'm looking for a quick connect fitting to attach an air hose to use that or air tools. You already have the compressor, go get the rest of the air setup.
And yes, I plan on attending the luau.
Old 06-03-08, 12:38 AM
Hil
Hil's Avatar
wow that is hot.. i only think id get a gs if i could get air. does it so much justice
Old 06-03-08, 12:56 AM
Caoboy
Caoboy's Avatar
How much was the controller? Any tips on the install? (whole system)
Also, can you go lower?
Old 06-03-08, 01:07 AM
chrispy
chrispy's Avatar
I think the controller itself is around $600 retail. DG on VSC is selling them a bit cheaper, maybe you can talk to her about it.
I suggest doing the trunk setup one day, and check for leaks. Do the bag install on a separate day. You'll minimize downtime this way. If teflon tape fails on you, try liquid thread sealant instead. It fixed all the leaks I had. If you have any other questions feel free to PM me.
I can't go lower right now without have a custom "washer" made for the rear. There's no way to get lower in the front other than RCA's. I cut the cap on the front strut mounts to get a bit lower in the front.
Old 06-03-08, 01:14 AM
Caoboy
Caoboy's Avatar
Cool. yeah I'll probably talk to you more on VSC about it.
Old 06-03-08, 01:22 AM
sleeper408
sleeper408's Avatar
That is a sick stance.
Old 06-03-08, 01:24 AM
4play4dr
4play4dr's Avatar
cleannnnnn..dint u get hit a while back? ur gonna have to look into how to get the rear to tuck rim..i kno UAS is capable of more slammage..looks clean for sure!! headlights look super clean too! lovin the photography
Old 06-03-08, 02:03 AM
Keen
Keen's Avatar
very clean.
Old 06-03-08, 04:07 AM
BlackoutGS
BlackoutGS's Avatar
great work bro. looks very clean! keep up the good work
Old 06-03-08, 04:14 AM
wowitztai
wowitztai's Avatar
Looks sick
Quick Reply: Air suspension installed! New Stance!
