Another Question About the TSIB Dustless Brake Pads
#31
Speaking of worthless dealerships...
Got my IS back from my first 5k service today- no TSIB. Doesn't apply to 08s. I have the "latest" brake pads.
Written on the "after" work summary is this-
"S104 Vehicle is equipped with high-friction front brake pads. Specifically designed for superior braking performance and response. Under certain conditions it is possible for the guest to experience a larger volume of brake dust. This is not indicative of a problem with the braking system. Tech 109."
Now, it's an 08... so technically they're right that it's not covered by the TSIB... but I was hoping I'd get lucky and they'd do it anyway... based on the comment above "certain conditions" is "using the brakes.... ever."
#33
Tech Info Resource
So you would never have rotors turned at all? Just use them until they get too thin? And if they are uneven, not worry about it,unless you noticed a huge vibration?
I ask because I wonder if I have a right to tell Lexus, despite the massive groove in my rotor,
https://www.clublexus.com/forums/sho...72&postcount=1
I don't want it turned, if they think it's abnormal, I only want it replaced..?
#35
Tech Info Resource
I would also insist on centerless grinding, not turning. It's how the brake discs are machined at the factory.
#36
DO you suspect the dealership is even capable of centerless grounding?
I'm guessing, but I'm suspecing the groove is about .75mm thick. In that case, you'd just leave everything as it is then?
#37
Tech Info Resource
#40
I just got it done last Friday with 14000 miles. They didn't machine/turn the rotors but it feels fine, no vibrations even driving downhill. I noticed the brake feel to be a little harder than before, not sure if it's the pads being brand new or the difference in material.
#41
I have almost 16k on my brake pads. They have an annoying squeek to it. Is it possible to still have the pads replaced with the tsib or will I have to pay for them? I have an 07 is250.
thanks
thanks
#42
I posted a while back and said that I had the TSB done and that I am still having issues with dust. On my invoice it says they installed 04465-30410 Pad Kit. I take it that is why - Correct?
#43
Tech Info Resource
If you still notice dust, they didn't put the right pads in the calipers.
