Susp. Gurus, an alignment mystery
The other day i aligned my car (yes me ) and something came up. When i went to adjust my caster angle on the rear LCA bushing (eccentric cam + bolt) i couldnt get the number to change at all. No matter how many times i tried turning the bolt the number did not change. Why could this be? Also the caster angles were really low compared to spec (3.05 degrees stock, actual was 1.3 degrees) and wondered if this had something to do with it. thanks
