Replace all 4 brakes or just the fronts?
I have 35k on the car now... read somewhere that it's recommended to replace your brakes at 20k... not sure if that's true... but i changed to the dustless brakes under warranty about 10k... so i'm about up for new brakes i wanna say
should i... replace just the two fronts?
or all four?
i know there's alot more stopping power required in the front... so the fronts is a definite...
any suggestions?
or all four?
any suggestions?
2IS OG
There's no mileage at which you "should" change the brake pads. Pad wear is completely dependent on your driving style - so you should change the brake pads when they need changing, not before. Swapping out brake pads before they're worn out is wasting money. If you do need to change your brake pads, only change what is needed - nothing else.
Javier
Javier
