Supra brakes
as far as i know the front should be direct replacement if not you'll need figs adaptors. i had 18"s stocks on mine and it cleared without issues. i have 20"s now and definitely no issues. you may want to upgrade your brake lines to stainless steel while you are down there.
https://www.clublexus.com/forums/sho...d.php?t=297958
Think about it. The supra brakes is one size...it won't morph and become larger on 3gs than the 2gs.
So, if the supra brakes clears with 18 on the 2GS..it should clear 3GS.
Imagine you pull the whole wheel assembly with tires and rims; rotor, caliper, and rims, and tires off the 2GS...now move it to the 3GS...nothing changed except maybe the fender clearance.
This is just from common sense...haven't tried it
