I am installing the following to make my car sit level tomorrow......
I will do a write-up when I am through. I am not even sure there is enough clearance between the coils to use them, but I am going to give it a try tomorrow. I am going to lower the passenger side, not lift the driverside. I need to lower it 1/4 inch both front and rear to make the car sit level.
enough of the suspense, Here is a link to what I am installing: http://www.sportsimportsltd.com/cospcoorsp.html
I can't possibly see how this can "mess up my car" I am simply compressing the coil a smidge, LOL. How could this possilbly mess my car up, Road Magnets give 2 inches of drop, I am looking to 1/4 inch of drop.
Needless to say I will do a write up on this when I get around to installing them.
I won't comment on what I think of your "solution"...
But I can't see how those things won't interfere with the basic function of the shock/spring, there's not enough room to install them.
Thanks for the pic Giggity. I am not sure if there is going to be enough room, They are pretty small so they just may work. I have been too busy today to do it. And I may take a nap so I don't think I am going to do it today.
I figured for $40 I might as well give it a try. Who knows it may not work, but I am willing to try it. It makes sense and if it fits between the coils then I am sure it will work fine.
Yes I am pissed I got rid of my coilovers.
There will be no pics because I did not get them to work. There is not enough space between the coils. I almost positively would have interferce undre compression. Damnit, now my 38K car has to lean and there is nothing I can do about it.
I swear the next car I buy I am going to measure and if it leans I am not going to buy it unless I plan on getting coilovers.
If it bugs you that much, contact GroundControl. I'll bet they may have under development a kit or could easily put something together that will give you a small amount of adjustability for about $300-$400 using the facory struts.
Tech Info Resource
