Brake pad upgrade part numbers
Hi:
I just got the brake pad update for the brake dust problem on the front wheels. After 2 weeks - no difference - the wheels are as filthy as ever! The part number they used for my 2008 IS250 was 04007-35153. This kit isn't listed in the brake dust 06/07 TSIB. Anybody know if these were the correct parts or did they just install the stock (soft) pads again?
Thanks: I think the part for the IS350 is different (bigger brakes). But I've been searching some more and apparently, there's another TSIB for "squeaking brakes". The replacement number for this TSIB is 04007-35153 (same kit they put on my car). Anybody know if the replacement brake pads are the same for the brake dust and squeaking brake TSIBs?
i dont know why but i think the NEW pads are less dusty?? when i got my car back in feb 07 the rims would get dirty in a couple of days.. then i did the TSB.. and the brakes brake like crap when you REALLY NEED THEM.. i changed them back to regular pads but these pads seem to have high performance and its been a week since i washed the car and barely any brake dust? its weird but im lovin it
Whereas they say 04465-30400 is the one that gives off less brake dust. Does this match what others are being told for the IS350?
i need brakes changed soon... i called dealer and 0046530410 is for the front and 0446622190 is for the rear...
not sure what the dustless brake pads are though...
called up someone else that gets me brake pads at cost... they said they're 3 different kinds of pads for our cars.... an E350 G350 I350.... i'm assuming it's the I350 being that the e and G probably correlates with the ES and GS...
can anyone confirm?
can anyone confirm?
they're are 4 kinds of pads now. I trying to order a set from sewells and i dunno which one is which..can someone help here?
This is for the '07 IS250
04465-30410
04465-53020
04465-53030
04465-53040
04465-30410
04465-53020
04465-53030
04465-53040
mystery solved.
took over an hr of search but i found it. Credit to IS350jet for posting it
https://www.clublexus.com/forums/sho...8&postcount=20
04465-30410 (IS350)
04465-30400 (IS350 - dustless)
04465-53020 (2006-2007 IS250 & AWD pads)
04465-53030 (2006-2008 - dustless)
04465-53040 (2008 IS250 & AWD pads)
04465-30410 (IS350)
Brake pad TSIB - AWD IS250 2007
I just looked back at the TSIB that was done a few years ago, they used part# 04007-35153 for my TSIB and when I looked at the PDF file that I found on the site it says part# 04465-53030. I read a few threads but couldn't find the information I need. I was told by Lexus Corp part# 04007-35153 is part of the TSIB. Anyone has any information to share? Since people are saying rotor don' go bad at 28k mileage. I don't brake like crazy neither.
Lexo_Tony
Suspension and Brakes
14
10-22-11 11:23 AM
Hameed
15
05-29-03 05:31 PM
