SUPRA break kit
Also does everyone run only salvaged calipers from Supra's or has anyone tried new or manufactured calipers from parts suppliers?
Total for parts like the ones shown in Coco-bun's pics (iie no shashin wa Coco-bun!) are like $600. Champion Toyota in Houston hooked me up. Hawk HPS pads from Tire Rack, a set of Rotora coated SS lines for the GS, and you're ready to rock n' roll.
I am curious. When I swapped the brakes on my mustang, it was essential that I swapped out the brake booster and master cylinder....otherwise the brakes the brake bias would be off if I used the stock pieces....
So, my question is this. Toyota put the stock stuff together because their engineers deemed it so. Now people add larger rotors and calipers. Does this not throw the car out of wack? If what I am thinking is accurate and please correct me if I am wrong, but won't adding something like this throw the brake bias off now that the front braking has changed?
Unless the Supra uses the exact same booster and MC that the GS uses, I am still wondering if this upgrade needs a different master and booster.
I realize that Ford and Toyota are different companies...but brakes are brakes...and I had to go through many Master's to get the right feel, and that if I did need to lock them up, nothing magically dangerous would happen....like the *** end kicking out by having the rears lock before the fronts etc etc etc.
balance is wack, but I think the gain you get from the Supra calipers are worth the change in bias. I haven't noticed anything dangerous from just driving on the streets, if anything, probably saved my *** a few times. If your ABS is working, it shouldn't lock them up.
Netz Toyota in Japan offer this as their BBK also. If you have a 98-00, you can get the bigger 01-05 brake booster, which from what I researched on Japanese sites, it does help a lot.
Brake bias is indeed off and I could definitely feel my fronts working harder than the rears. I'm not using the supra setup (LS400), but I could feel a bit of fade with the OEM pads after a while.
The best thing you can do aside from getting new master cylinder (we dont have much options to choose from as the OEM unit is already complicated as it is), is to get different rear pads. We can offset the bias a bit by running pads with higher coefficient of friction.
I had some major brake issues in my car so I added an adjustable proportioning valve. I was able to dial in my brakes perfectly. I did tests on my parents gravel driveway. Turn the ****, and see when the brakes lock....but I did not have ABS, so I have no idea how to do it on a Lexus....or if the adj pro por valve is even viable. I doubt it, but it worked on my Mustang.
I have the **** style.
http://www.wilwood.com/Products/006-...1-PV/index.asp
Yea the fronts do most of the braking but the upgraded calipers are A LOT more powerful than the OEM brakes when it comes to brake horsepower so for all we know, we could have shifted the bias even further.
Unfortunately, we cannot add an adjustable proportional valve to the GS. Unlike many master cylinders out there, the factory valves are integrated into the master cylinder. It's just one big unit that comprise of the ABS, proportional valve, and the cylinder itself. Pretty hefty price of $1200+ should it ever go out on you. Adding on the valve to the rear lines is not feasible. Two valves dont make a right
Are you sure they're supra Calipers. The SC guys can fit them but I dont know anyone who has rear supra calipers on their 2GS. Just make sure you're able to retain the E-brake. The hub inside the rear disc may not be the same.
