SUPRA break kit
#36
I can't seem to find the details of this swap.
Is it simply rotors and calipers and supra bracket? Simple bolt on like my 2000 Buick Park Ave Ultra from the stock 12" brakes to the Bonneville GXP 13" brakes? Simplest bolt on affair I have seen. You can upgrade the C&H Body GM cars from 11 to 13" brakes as fast as you do a brake swap.....
Can one run the GS caliper on the supra bracket? Is there a reason to go with the harder to find Supra caliper? Other than cool looks?
Pondering the swap, but need 17 wheels first...
#37
#41
#44
So, should I buy stainless lines for the 2GS, if doing either the LS400 or Supra TT front upgrade?
Does anybody know what the thread size is that goes into the hard line? (if so, the guy at SilverMineMotors.com said he can make the lines for our car, on demand)
Lastly- Does anybody know if it's 10mm or 15mm spacers needed for the stock (5-spoke) wheels to clear the mk4 Supra TT calipers?
For the LS40 brakes on the 2GS, I keep seeing at least 15mm. Just wondering if it's actually (slightly) LESS when running the Supra brakes ?
#45
Looks REAL NICE, bro.
What size spacer are you using to get the stock wheels to clear ?
I'm assuming I'd probably need the same (or SIMILAR) size spacer to get the '98-'02 (5-spoke) 17" 2GS wheels, to clear on my car...
WHAT DO YOU THINK?
WHAT DO YOU THINK?
front yes, rear no
I just ordered everything for a 1998 Supra Turbo.
Calipers, rotors, pads, shims, and wheels that'll clear the calipers. You can use the stock brake lines but doesn't fit perfectly. There's a "hook" (sorry, hard to explain) that just barely doesn't fit.
yes, bigger.
You're welcome?
yes, bigger.
You're welcome?
WICKED SC4
Suspension and Brakes
51
12-09-07 11:50 AM
mikevanle
07-17-05 09:58 PM
