LOSS OF CONTROL - rear end Bilstein Sports on stock GS 400 suspension
Twice under heavy braking or quick maneuvering, my GS 400 has lost control having the back end slide out to the left. I have Bilstein Sport Shocks on all four corners on stock springs and stock wheels with newer tires all around. I was wondering what mods would help most with this problem?
Sway Bars? Strut Bars? New Larger Wheels n Sport Tires (18" probably)? New Springs with a mild drop (1")? I am trying to get the biggest bang for my buck here as well.
Thank You
Thank You
The car basically drives like a 74' caddy when stock and worn out. What do you expect? https://www.clublexus.com/forums/sho...d.php?t=297958
Car needs to be lower, stiffer springs, wider rubber, and yeah check out your ABS & traction control systems.
