Aftermarket Drilled Slotted Rotors and Noise Issues
Slotted are less prone to be damaged, slotted and drilled are more prone.
I have seen cross drilled slotted rotors fail on the race track...split completely down one side. Now normal driving is not racing, but if they fail, they fail, and you're screwed. I'm sure you all know, but back in the day, the drilling was used to dissipate gasses that would build up between the pad and rotor. With new technology in pads, this is not even a concern and certainly not enough to warrant it on a street car.
I run 13" brembo blank rotors on my Mustang and beat the hell out of them and they never give me problems, and I get them very very hot with the race pads I use.
I used to like the look of drilled rotors, who doesn't? If they actually gave a benefit I would probably get them, but seeing what I have seen, I'd rather spend the money, like someone else said....get larger calipers with more pistons, better pads and good rotors. Way better than some bling bling brake rotors.
But that's only half the battle. All of the new brakes won't mean a **** in a bucket if you don't have good tires. Ever try locking up Brembo 4 piston calipers on some old crappy mismatched tires? (I have, moving a car with crappy wheels and tires while the race rims were at the powdercoating shop and I decided to be a jackass) It's ugly. REEEEEALY ugly.
I know this is a Lexus Forum But I was looking at different people's thoughts and saying's about Drilled and Slotted Rotor's I have a 2006 Chevy Silverado 1500 reg cab with 20" wheels on it I installed Crossed Drilled and Slotted Rotor's with Power Stop Z16 Brake Pads The only sounds I got with these rotor's was taking off from a dead stop or getting up to 20-25mph sometime it done it if I was driving at 40 mph I can let off the gas and it stops I give it gas and stay at that speed comes back for a few seconds and stops. Or if i just give it some speed it stops with the sound.
Mine is more like maybe metal brake clip deal thing that maybe the rotor is touching it. kinda sounds like someone shacking a set of keys on a key chain lol kinda hard to really explain it Its not very loud But Iv tried everything I can to stop it but no luck I drive this daily which I got use to the sound and said whatever lol I don't think people really can hear it tho because know one has gave me a look or anything lol.
I think I know what mine really is doing know but I don't know if you can remove it or not but it's a part that the brake pads sit on It's a small metal clip like deal It broke after installing Drilled and Slotted rotor's and that's when my sound got quite but still their.
Photo will show more what I'm talking about.
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/308953_108755702604788_1352312978_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/482051_108765882603770_1579657064_n.jpg)
This myth I keep hearing on these forums about better brakes. What you really mean is that you brake with less pressure on the brake. Big brakes are better if you are on a mountain road or on a race track where brake fade becomes an issue. As far as braking, it is the tires that matter. Ask yourself, can I lock my tires up? (or does the abs kick in?) then that's the fastest you are going to stop period, regardless of what brakes you have. So when you say a slight improvement do you mean brake fade? Brake feel? Because unless you also changed your tires, suspension or something else it most certainly is not stopping distance. Be specific
Im kicking dust off this one to freshen it for those looking for slotted & drilled rotors.
So rotors, be it slotted, dimpled, drilled, are not going to improve braking unless the material is different. Take for example the ZR1 Corvette with carbon ceramic rotors. Those slotted and drilled rotors look cool but really if anything increase your stopping distance because of less than stock rotor surface. Those designs are really intended for race. Where the rotors see maximum duty and a great amount of heat. In day to day driving they benefit you none.
As for noise. The past owner of my car "upgraded" to slotted and drilled rotors but kept them at the stock size. So the fronts warped and shimmy during any speed of braking. The rears make this odd cricket / clicking noise at low speed braking. So I now have to go back to stock because bone stock GS400s shouldn't be a pain to drive but have stock sized "race" rotors. moron (head shake)
I will say this if you really think your car needs better brakes look into Hawk HPS pads (high performance street). Its a pad that I ran on a previous car of mine. It is hands down a great best of both worlds pad. Easy quiet day to day braking with little to no dust but do a few highway speed halts to get them warm and you better hope you like the taste of your steering wheel.
Another realistic brake upgrade option is to increase the rotor size with an actual brake upgrade.
Bigger rotor pros:
More leverage from the center of the hub = greater braking control
Bigger rotors dont fluctuate tems as much as thinner smaller rotors
Bigger rotors often have bigger vanes for better heat dissipation
Larger pads, that means less pressure per square inch to do the same work = less heat, more control
Aesthetically, filling up the rim with big brakes looks cool too.
Bigger rotor cons:
More rotating weight
(Rotating weight carries centrifugal energy. Lots of spinning weight is harder to change direction)
More unsprung weight
(1lb unsprung=10lbs sprung weight)
Hope you had the time to stop and read all that and I hope you can take away something useful from it before you spend your money unwisely.
Bigger rotor pros:
Bigger rotor cons:
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I've been chasing a groaning, rumbling noise on an 03 430 for several months. New pads and calipers. At first I did not suspect my drilled and slotted rotors because they were so new. After reading this post, I thought -- could it be? Yes, I put on new blank rotors this morning, and it is very quiet again. Interestingly, I had no noise issues when I first installed the drilled and slotted rotors, but then 4 or 5 months later, the noise began, and today my brakes are quiet and smooth as silk. I'm staying away from drilled and slotted rotors. Thanks for the post. :
I got a set of EBC gold series rotors which are dimpled not drilled. I had ebay drilled and slotted rotors that were super loud with the clicking noise on the car before. Now with the EBC there is a very faint click noise that you can only hear with the windows down and the radio off. It not bad at all.
Wonder if anyone is still here we'll my 250 recently started making like a clicking/ rubbing nosie on my drilled and slotted rotors. I check yesterday after taking off my wheel and brakes but found nothing? Are they supposed to make nosie? What I did notice tho was my brakes were getting use at only the corners at angles is that normal? I don't recall my brakes doing that but then again i was running oem rotors before so idk if it's a rotor thing or something.
ReyRey305
08-02-11 11:58 PM
