Just installed Tein S-Tech's on my IS250 RWD
First off, i want to thank Zexnos for letting me use his garage and taking time out of his day to help with the install.
I think these springs are great. Its a little stiffer over bumps, but overall a very comfortable ride. If you've never been in a 250, then you probably wouldn't even know that springs were installed. I think after all the research that i did, i made a god choice of springs. I wish the fronts were a little lower, but i'm satisfied. Im on stock 17's, almost traded with Zexnos for his 18's. Here is a pic 2 days after the install:
the back is actually higher up from the ground than the front is. i took measurements. I'm on stock 17's which are smaller rims and then tire size on front and back are different. The higher sidewall on the rear tires fill up the gap more than the front. If you take a look at most other cars on here that are lowered with springs, you will notice there is a bigger gap in the front as well.
All the suspension experts, correct me if i'm wrong.
showjet95
Pacific
06-15-13 10:03 PM
