I Need NEW ROTORS, HELP!!!!!!!!!!!!!!!!!
Absolutely so. Drilled is for a show car because it "looks good". If you care about better parts you don't drill holes in rotors, it makes them weaker and reduces their mass (which is what absorbs the heat from braking) It's unfortunate that the fast and furious crowd has made the cool looking drilled rotors an expected feature so even many performance cars are using them when they'd be better off with slotted for the track or just plain blanks for the street.
Larger brakes won't stop the car in any shorter distance, no matter what you do to the rotors.
I'd suggest you read this article-
http://www.scirocco.org/faq/brakes/p...n/pfpage1.html
It explains what actually stops a car, and it explains what upgrading each component in a brake system CAN do and more importantly what it can NOT do.
In short though, if you are not:
Taking your car to a racetrack
Driving down steep mountainsides
Involved in a chase scene from a Bourne film
then no brake upgrade will be much more than costmetic. At best you'll change the feel of the system while still being able to stop in exactly the same distance you could before.
Yeah, just for looks, as long as it clears the wheels, go for it... the rotors (if drilled) will still be more prone to cracking, but if you're not tracking the car you'll never notice any loss of heat capacity from the holes at least. If you don't strongly prefer drilled over slotted then get slotted, they'll last longer and if you ever -do- track the car you'll be better off there too.
I will probably never track my car, so getting drilled over slotted shouldn't be a problem right? I just like the way they look, that aggressive look is going to look so sweet, DO THE TYPE OF ROTORS CHANGE THE WAY MY CAR WILL STOP?, DON'T WANT TO GET TOO TECHNICAL SO YES OR NO WILL DO, hehe!!!
thus far im having no luck with drilled rotors for our car from a reputable company, stoptech said they only had drilled, HEEEELLLPPPPP i want drilled, after searching online I founf a couple of new brands that im not that familiar with........ here they are , TELL ME WHAT YOU NOW, AND WHAT ABOUT DRILLED AND SLOTTED?
BRANDS I FOUND THAT HAD DIRECT REPLACEMENT:
ROTORA ive heard of them before
http://www.gripmotorsports.com/dl~pn...ke_Rotors.html
http://www.vividracing.com/catalog/b...d=8&class_8=24
DISCITALIA ??????? never heard of but maybe descent drilled and slotted
http://www.lexustech.org/Brake2.htm
EBC ????????????
http://www.horsepowerfreaks.com/perf...s/Brake_Rotors
EBC ????????????
There's probably a reason the reputable companies aren't offering drilled ya know :P
Most "real" performance brake companies are selling brake upgrades for performance reasons- which is the opposiute of why you'd put drilled rotors on usually.
For what you're doing with the car you're not going to notice any difference in stopping distance... you certainly might notice a difference in the "feel" of the system though.
For street use, quality cross drilled rotors will not crack. They will probably wear out before they crack. I have a car that has 20k miles on it with cross drilled. No cracking at all and it has been through stops from 120 mph
IMO any brake upgrade on the IS350 is all show and no go IMO...just as much of a waste as any aftermarket INTAKE for the car. If you are going to show your car then I do see the benefit. If not save your money and get something else IMO.
I tried the EBC Red Stuff ceramic pads on my IS350. Great pads hands down and just as much dust as the OEM. Its easier to clean but I don't feel any difference what so ever!
Any brake upgrade on -any- car with a decently designed OEM braking system won't produce any results unless you're taking the car to the track or frequently driving down the side of a mountain.
I'd again encourage folks to read the link posted earlier.
Now, that said, will drilled rotors fall apart the first time you use em? Of course not. Probably not the 100th or 1000th time you use em either. But are they -more- likely to crack than a solid disc? Yup.
Do they stop the car any better? Nope. Potentially they stop it worse, but again only in situations 99% of drivers won't ever be in.
They're pretty though.
