NEED help!!
NEED help!!
I have tein SS on my 2IS, im having uneven wear on my tires, and i heard someone said i need to get camber kit?? what should i do to fix my uneven wear on my tires, thanks
an alignment may help, but wont correct the camber wear. i remounted my tires left to right to get a little more life out of them. Its the price you have to pay to play, for looks/ handles that is. good luck, hopefully some camber kits will be coming out soon
How did you remount the tires from the right to the left?? doesnt the tires have grooves that has to go a certain way??
Ho Motorsports
You need to make sure your alignment is good. If you have directional tires, you can flip your tires every 5000 miles when you do your oil change. It means you take off your tire from your driver side wheel and put it onto the passenger side wheel and vice versa. If you're slammed on the coils and your alignment is good, flipping tires will prolong your tire life.
Terrance
Terrance
You need to make sure your alignment is good. If you DO NOThave directional tires, you can flip your tires every 5000 miles when you do your oil change. It means you take off your tire from your driver side wheel and put it onto the passenger side wheel and vice versa. If you're slammed on the coils and your alignment is good, flipping tires will prolong your tire life.
Terrance
Terrance
Ho Motorsports
Um, you don't get the idea of flipping tires I guess. If you have DIRECTIONAL tires, you have to take the tire OFF your wheel first. That's what I said. It's not taking the whole wheel off and swapping sides. Please read it carefully first before you correct it.
Terrance
Terrance
Even if you DO have directional tires, you CAN pro long the life by flipping tires like T-Rex has said. You have to DISMOUNT the tire from the left rim and remount on the right rim. Vise versa.
As long as it doesn't say OUTSIDE & INSIDE. You are good.
I think he's confusing directional with asymmetric design. Directional has the same tread types on both sides of the tire making it so you can dismount and remount left to right. With an asymmetric style the tread varies from left to right so you can't functionally flop the tires.
