daizen rear sway bar
i installed front sway bar bushings from daizen they had a slit in them to go on the bar. The rear bushings are diffrent there is no slit in the bushing do i have to take the sway bar fully off and slide them on from the ends thanks sorry for the spelling
rich
rich
I found the same thing with mine... no slit to get them on. I called Sewell who, I bought them from and they stated to slide them on..LOL
I need to call them back and discuss this...they will not "slide" on.
Confirmed,
You must split the rear bushings with a stanley knife. Use the same cut-angle as the front bushings.
The bushing will simply not go over both the end of the bar (connecting holes) and the bend without damaging them.
Also by splitting them, you dont need to disconnect the bar from the linkages.
Champstar
02-17-11 07:42 AM
