Is there a diffence in size on the rear sway bar...
...between a stock '93 and a stock '97 SC400? I found out the later model 97+ Supras got smaller rear sways but am not having luck finding out for sure about the SC. I ask because I used a set of Daizen rear sway bushings off a wrecked '93 but my stock sway on my '97 is noticeably smaller diameter. The sway bar from the '93 matches the bushings perfect so I'm putting it on my '97 now too. Is an an aftermarket bar or what?
Either way, the thicker bar from the '93 fit well and is noticeably stiffer in the corners. I would be interested to know still if there is a difference from the factory sway bars between the years. Any input would be appreciated.
So I assume this could be a upgrade from stock on the '97+ if you're looking for a little better handling. It certainly feels better in the corners. I wonder which of the fronts is most agressive?
Good luck finding one, I searched through the junkyards on Broadway in Phoenix and they have nothing. I found a lot of LS400s though, and Altimas lol.
I agree, look at the Daizen website and check the application for the swaybar bushings, the pre-97 and 97+ are different.
Hey I'm bringing this thread back because I recently purchased a supra tt rear sway bar from a 95 supra tt. I haven't installed it yet because I still need to purchase the subframe mounts. I've installed TT sway bars before on my 97 sc300 and everything bolted up fine.
Now I have a 93 sc300 and I noticed they do look thicker. I haven't measure exactly though. And the supra tt rear sway bar is the same thickness from my 97 oem rear sway bar. I know this because I still have my OEM 97 sc sways from when I replaced them before.
I've read that the 97-98 supra's are 20mm and pre-97 supra tt are 22mm. And the SC is supposed to be 22mm.
So I just wanted to know if anybody has ever measured their pre97 sc rear sway bar? And is there a oem supra rear sway bar that is the same thickness as the pre-97 sc?
benbuilt4u
Suspension and Brakes
05-28-11 07:09 PM
