How BAD did I MESS up my BRAKES!!!!! HEEELLLLPPPPP!
yes that is the part that i am talking about. My bolts will be in tomorrow so hopefully i will be able to just screw it in with no problem and not have to worry about the caliper, we'll see.
I dont know how to bleed brakes, and im a little skeptical of removing the caliper although its just held on by the hose; however getting air trapped inside the system is my biggest worry (read it somewhere on the forum). I realize in order to properly fix this i will have to take the caliper off, be it timesert or taking it to a shop to get it tapped which i'll probably do to get it done right.
Tech Info Resource
You would be smart to clean up the threads with a 12 x 1.25mm tap. Despite what some would tell you, use engine oil or tap oil on the tap. Don't use WD-40, it's got no lubricating ability at all and you really only want to take as little metal as possible. Engine oil, or ideally tap oil, will do this well.
If you use the new bolt to clean up the threads, expect one of the new bolts to be junk after you run it down and back.
I'd buy a new caliper. Brakes are something you don't want to chance. You are looking into a new caliper at least. I thing that if you end up repairing this caliper the bolt may loosen or fall out.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Tech Info Resource
It would be a lot cheaper to take it to a decent machine shop and have it repaired. It's just a blind nut pressed into the caliper. It's not like the integrity of the caliper itself is in doubt. I can think of about 5 ways to fix it without spending more than 30 minutes on the whole process, so in all likelihood, it could be repaired by a competent machinist for $100 or less.
UPDATE: today i recieved the new bolt; however getting it in there was a pain, so i used some oil and the old screw and it went all the way in, i was able to torque it and everything. the caliper insert is stripped but its in the middle somehere but if you try hard enough the bolt will pass through. Thanks for all the help guys!
Lesson learned never impact wrench without hand tightening to the maximum first, those seconds of noise will cause you a night of pain! LOL
thanks guys, big ups to luboxracer for all the help!
Helicoil insert and it will be as good as new. The bolt does not see much axial force so it should be fine. Never use an impact wrench to screw down a bolt!!! That's madness imo. I could help you out but you're in TX.
reminds me of the first time i did my brakes... i broke the head of a bold off in the caliper. i nearly ***** myself. i took it to a machine shop and had them re-thread it for me. only cost me $25.
