F-Sport Shocks
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
sorry, I hope you know I don't mean to sound like an engineer, i think it's called damping ratio when you're talking about the shocks. Damping ratio relates to the viscosity of the fluid/air inside the shocks to create a stiffer damper/shock. Hope this helps. =P
I really dig the F-Sport Shocks too, but I think i'm too cheap...i may just have to stick with my x-Package sports tuned suspension and just get the springs. =(
The F-Sport are a Patented design by Bilstein. They are mono tube and the OEM are twin tube. You will not find a better strut on the market unless you go to a coilover with the mono tube design. The strut travel is the same with both tho. You should be able to run any of the aftermarket springs with no problems. I think the Tanabe DF210's for the GS are the lowest drop at @ 2".
My buddy at the local lexus dealer just confirmed the same thing. They're pricey though, for the price of the F-sport shocks, you might as well buy some quality coilovers and ditch the F-sport shocks and lowering springs combo.
That's exactly what I did, for what the F-sport spring and shock combo cost, you can get a decent set of adjustable coilovers, I was careful to choose ones that had montube struts. Over the years I have come to prefer monotube over twintube because they seem to offer a nice middle ground between comfort and aggression.
We used to do with with mk2 VW shocks, cut the shock at the top, take out the shaft and piston drill a hole at the bottom of the strut housing, clean up where you cut it off at the top and use a Koni insert. So the OEM strut housing becomes a casing for the new koni insert.
You could be a pioneer, buy your self a set of used oem struts, contact Koni and see if they have an insert that would fit the OEM strut housings???
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
