Riding Low on Driver's Side
I've got a '92 SC400 and the driver's side is noticeably lower than the passenger side (about an inch). It is probably sagging as the springs have never been changed. I don't want to change the suspension setup, but the OEM parts are probably pretty expensive. What is the best advice to keep it fairly stock at a reasonable cost? Thanks in advance.
It presumably happened over the years - I didn't notice it until a friend pointed it out. I usually don't have passengers so it could just be that the springs/shocks on the driver's side have worn out sooner than the other side.
"what springs did you get? are you on coilovers or just lowering springs?"
I haven't got anything yet - Looking for suggestions. It is stcok original and I want to keep it fairly stock in ride and handling. Should I change just the springs or the shocks as well? What would you suggest?
What is the difference between replacing the springs, replacing the shocks and a coilover? It looks to me like the stock units are combination shocks/springs.
The SC has a tendency when stock to sit a little lower on the driver's side for some reason I've heard. I agree with getting some new shocks/struts first though and seeing what that does for you. Coilovers will let you adjust each corner to whatever you want.
I noticed my car was about 1/4 inch lower on the driver's side when I was running my Eibach spring with stock shock setup...I replaced my spring and shock setup with Tein CS and problem was solved...Although I must admit the driver's side does camber a bit more than the passenger...Go figure...
Nothing is perfect...
Most cars sit lower on one side than the other from the factory. Its just much more noticable when the car is lowered and the gap in smaller from the top of the tire to the fender. Cars are designed like this from the factory for water run off. to keep water from sitting in body lines. Ive been told that it is the body that is mounted slightly lower on one side not the suspension. So DO NOT compensate for the difference by raising your coilovers on one side.
yup, after I lowered my car, I noticed the same thing. The drivers side was WAY lower than the passenger's side. Same with one of my friend's NEW IS350 lowered on NEW eibachs. I dont like that
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
