I'm tired of cleaning the brake dust off of my wife's IS250. SO...
#46
Will Lexus release a TSIB for the 09 cars? Most likely, if enough people complain. If people continue to complain, im sure Lexus will start re-focusing on luxury and not care so much about performance in the future. Thats a step backward....
#48
Im trying to understand why people dont realize that there IS NO PROBLEM TO RESOLVE. This is the way Lexus designed the braking system on this car! So there is no problem to resolve. Lexus took it upon themselves to address this concern that some owners were having, by releasing an ALTERNATIVE brake pad set that customers can have installed under warranty. Again, the dust is NORMAL. It is a byproduct of superior braking components, designed to give the best pedal feel, performance, resistance to fade, etc.
Where the TSIB pads will offer -exactly- the same performance as the original high-dust ones, with a smoother pedal feel too.
For the 1% that take the car to the track they can swap on different friction material for better resistance to fade with repeated high-speed stops.
That makes a lot more sense that doing it the other way round.
#51
Excuse my noob question ! But what is TSB ?
i have a is250 2009 in Sweden, and the same problem with the dust ! and i have chrome wheels so its even more problems with them.. so i wounder what this TSB is that every one is talking about and if there are other new ways to minimize the dust ?
#52
They replace the high-dust pads with ones that don't produce hardly any dust at all, for free under warranty.
(which is what I'd suggest you do, assuming it applies to cars outside the US... and if not I'd still suggest it as the best solution, you'd just have to pay for it)
#53
This is not a step backwards IMO. Customer satisfaction is a positive step. My last 2 Porsches had high performance brakes with lower dust output than the IS350 with the old front brake pads.
Btw, Mercedes with the new C-Class has had a similar issue with rear brake pad dust and they also have addressed the issue with revised pads for the customers that complain. Again premium car makers are listening to the customer and coming up with solutions to address customer concerns and maintain premium car performance.
#54
Last time I tried doing the TSB, they didn't want to do it because my car is an 08 and the TSB ended with '07s. But then I found a different dealer who were willing to do it for me for free, but the manager warned me that I might get some squeal from the new pads. He also explained that Lexus were making a new version of their pads that wouldn't have any squeal or dust and they were supposed to arrive this year. So I'm still on my original pads, since I wanted to wait for the newer version. I don't know if I should just go and get it done.
#55
In mid-09 the official OEM part was supposedly changed to be the low-dust pads, but they're the same ones used since the TSIB was first issued.
If installed correctly there should be no noise issues (there were certainly none on mine)
#57
I had low dust front pads installed in June, brake dust is reduced by a huge amount on front wheels.
#59
F is for Fraud
Might as well put these in your car. The Kleen Wheel covers are far too tacky for a car of this level... seriously, invest in a good pair of low-dust brake pads or get the TSB done. It helps.
![](http://ecx.images-amazon.com/images/I/41Mwr4kDLJL.jpg)
