Brakes.
Last Saturday I changed my rear brake pads(was pretty amazed how small they are) due to started squeaking noise, I thought old ones were already worn but to my surprise they were almost brand new, well since I bought new ones and as I could see it was super easy to change them(never seen anything like that before
) I decided to change them anyway. After I changed my rear brake pads, I didn't notice any difference at first but now when I'm driving with open windows I can hear that there's somewhat loud(not really loud but noticeable) ticking noise coming from rear right wheel. Ticking noise only stops when I'm pressing on brakes. It's pretty suck to drive Lexus with this noise, just ugly. Well does anybody know what can cause this? I'll take it apart tomorrow and see what happens, probably try to swap old pads back since they're almost brand new anyway.
So, any ideas?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thanks.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
So, any ideas?
Thanks.
iModerate
Thanks.
So, any ideas?
Thanks.
I have that EXACT issue going on right now. Even down to the same wheel! I did not change my brakes though - just installed new wheels and tires. I picked up a brand new set of rear rotors today an the issue got worse. While test driving it slow I switched to reverse and herd a metal snap. The pad springs on that wheels caliper popped loose. So I'm off to Lexus tomorrow to get the "Fix" or "Fit' or whatever its called kit.
Let us know if and how you get this issue corrected.
The metal plates that sit on the backing plate of the brake pad. They shim (insulate) the brake pad plate from the actual caliper pot. Most aftermarket pads only have on shim and sometimes its permanently connected to the brake pads.
When I was changing my brake pads, I didn't really fixed that fix kit(read I installed them incorrectly) so I lost both to them. I went to dealer, 3 mins away from my house, bought "fix kit" for $20, installed them in correct way and now problem solved ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
So by looking at picture below, did I installed them right way this time?
I hope I did.
![](http://i290.photobucket.com/albums/ll251/vadimsbc/Picture241.jpg)
What is this "fix" kit? I am about to change my brake pads myself after a get some brake pads. I am hoping it will be a relatively easy thing to do and not too nerveracking. It looks fairly easy from some of the pictures I have seen but things always look easy and then too difficult real quick when working on cars.
iModerate
I hope I did.
![](http://i222.photobucket.com/albums/dd79/iamthor_photos/Rear-Fitting-Kit.gif)
iModerate
The darker green is under the larger clip.
iModerate
The thing is I bought the car in April and was driving it half year without those M springs without any issues. I mean I can buy those springs and install but if it will be fine without them I just don't want to remove wheels, jack up the car etc for such small part that won't do anything.
