Anyone with ISF brakes on?
Old 02-07-16, 09:42 AM
  #106
Gville350
Gville350's Avatar
Bleed the entire system through the driver's side rear caliper after completed. It's the furthest bleeder from the master cylinder.
Old 02-07-16, 11:23 AM
  #107
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Exclamation
Originally Posted by flowrider
^^^^Yes, no such thing But, if it were air, you could pump the pedal and get the level to raise and feel firm.
Lou
Actually if it's air, you have to bleed it out of the system, as mentioned.. Any Air in the brake lines, has an adverse effect in the pedal / pressure.
Joe Z
Old 02-10-16, 11:11 AM
  #108
WylieKylie
WylieKylie's Avatar
Originally Posted by badx33
So I installed the rear ISF calipers on my car today and i had to buy longer studs and use a 8mm spacer. For anyone that has 18's wheels and plan on installing isf brakes you need to check your spacing. Im running 18x9.5 with a 25mm offset in the rear, so now with the 8mm spacer it went down to a 17mm and it finally cleared the caliper.
I'm reading back through this thread, and this caught my eye. Did you really just put ISF calipers on the car, or did you put on calipers and rotors?
Old 02-10-16, 11:28 AM
  #109
flowrider
flowrider's Avatar
Received 1,902 Likes on 1,342 Posts
^^^^Here's a pict from another thread posted by badx33. He used ISF sized 2 piece rotors.
Lou
Attached Thumbnails Anyone with ISF brakes on?-efc67013-96c6-4cff-80bc-26639a65a6e4_zpsoiabd0iu.jpg
Old 02-10-16, 01:45 PM
  #110
badx33
badx33's Avatar
Hi there, yes i swapping complete front and rear ISF brakes and Figs two piece rotors.
DmmitLana
Suspension and Brakes
03-21-16 06:28 PM
nikogio38
06-14-15 11:23 PM
R6_Dude
07-30-09 09:14 PM
ted920
IS F (2008-2014)
51
05-11-08 10:11 PM
Quick Reply: Anyone with ISF brakes on?
