Official F-sport Sway Bar Thread!
Old 07-09-10, 03:28 PM
  #301
flowrider
flowrider's Avatar
Received 1,896 Likes on 1,337 Posts
Originally Posted by brociouz
That's wrong. They are definitely different. If they were the same, the values for IS250 RWD and IS350 RWD would be identical in the chart below. You'll also see in the chart below how small of a different the F-Sport front sway makes on an IS350. I don't think anyone will notice a 6.3% change in stiffness. The only reason I can think of for getting an F-Sport front sway on an IS350 is to be a brand *****, because you're OCD and/or you have so much money you don't care. ]
That is NOT wrong. When I compiled the attached chart, I contacted Lexus, and through much teeth pulling I obtained the sway bar diameters. I then called a Lexus dealer's Parts Department, and verified that the PNs for the IS250 and IS350 RWD models were the same.
Lou
File Type: pdf
Old 07-09-10, 03:38 PM
  #302
brociouz
brociouz's Avatar
So you're right and Lexus corporate (where that chart I posted came from) is wrong? Call me a skeptic, but you're making a pretty bold statement. Anyone else care to chime in?
Old 07-09-10, 03:40 PM
  #303
SC3coupe
SC3coupe's Avatar
The confusion here is the picture claims IS250 have thinner front sways than IS350, but Lou said it's all the same. I can go under my car with caliper and measure the front sway bar size wise
Because I want to know also before I make a decision.. not going to pay $300 extra for 1mm increase
Old 07-09-10, 05:08 PM
  #304
Kurtz
Kurtz's Avatar
Lou
I know you've mentioned this before.... but I know I've also mentioned the same thing the previous poster has...
Which is that the F-sport sway chart would make no sense whatsoever if the OEM bars were the same between the 350 and 250 RWD models.
So either Lexus lied to you on the phone, or they've lied in every single thing they've ever published regarding the F-sport bars. Both can't be correct.
Old 07-09-10, 05:17 PM
  #305
syzygy
syzygy's Avatar
Yes, the stock/OEM front IS350 sway bar is a great upgrade for IS250 RWD owners. It will give you almost identical gains to the F-Sport front sway, for a fraction of the cost. The trouble is that many IS350 owners know the front is waste of money, so only get the rear F-Sport sway and thus you don't see many used IS350 front sways for sale. For the rear on an IS250 RWD, you might as well get the F-Sport though.
Check, check, and...check
Old 07-09-10, 05:42 PM
  #306
brociouz
brociouz's Avatar
Exactly, I find it a whole lot more likely the random guy on the phone lied to you, or simply made a mistake.
Old 07-09-10, 06:02 PM
  #307
gocubs08
gocubs08's Avatar
Ok, so speaking in all OEM that chart is saying that the IS250 has a stiffer OEM rear sway bar than the IS350? and the IS350 has a stiffer front bar than the IS250?
interesting.....
Old 07-10-10, 08:42 AM
  #308
ilv1004s
ilv1004s's Avatar
F-sport bars are the same for 250 and 350 (both RWD) if that's what you mean.
If you mean the factory bars...really, just get the F-sports.
oh yeah
cool thanks
just didnt undestand the stiffness % increase
on the 250 and the 350
Old 07-11-10, 01:03 PM
  #309
towi
towi's Avatar
Originally Posted by towi
Could someone PM me a copy of F-Sport front sway install instructions for IS250 AWD or a download link to pdf?
I've misplaced my copy and based on what i remember about the steps, i'd rather do it with instructions at hand.
Anyone? Please!
Old 07-12-10, 10:24 PM
  #310
CleverName
CleverName's Avatar
Just finished reading this whole thread.... Studied the Eibachs and Hotchkis(sp?), and called my local dealership and ordered the set. Will be in tomorrow.
Had my '06 for what? 2 weeks now? And already mod# 1 to my Lex. (Here i go again.... )
EBC red stuff showing up too...
Vince
Old 07-13-10, 09:51 AM
  #311
Darkchylde
Darkchylde's Avatar
Default IS 250 sway bar installation instructions
Anyone? Please!
Hope this helps
http://is.sewellparts.com/accessorie...-2010-360.html
Old 07-13-10, 05:53 PM
  #312
alan003
alan003's Avatar
Hi everyone,
I was trying to install the f-sport rear sway bar and realized that the bolts were really tough to remove (space is really limited and maybe i am weak lol). I sprayed some wd40 and no use, the bolts won't budge. For those who install it themselves, can you give me some advices/tips on this. Thanks!
if anyone around the 626 area and willing to help me out, that will be awesome too! :]
Old 07-13-10, 05:58 PM
  #313
SC3coupe
SC3coupe's Avatar
Originally Posted by alan003
Hi everyone,
Which bolt? get your car higher in the air (be careful) and get a bar to go over the ratchet or wrench..
Old 07-13-10, 06:26 PM
  #314
alan003
alan003's Avatar
^ the bolt that ties to the end link. if i remember correctly, left is tight and right is loose?
Old 07-13-10, 06:29 PM
  #315
syzygy
syzygy's Avatar
The common phrase is "righty tighty, lefty loosey" but I have no idea if what I'm saying applies to your question. Turning a bolt clockwise means you are tightening the bolt. To loosen the bolt, you have to turn it counter clockwise (left).
Quick Reply: Official F-sport Sway Bar Thread!
