Official F-sport Sway Bar Thread!
#512
Installed the FRONT bar today, Ive had the rear bar only for over a year... I can say (with my suspension and tire set up) this bar does make a noticeable difference. Ive been driving the car really hard (there is no speed limit where i live) lattley. and with this fron bar, the car leans less on hard turns and the rear tires feel more planted on hard turns. Before the car would lean too much making the rear tires spin out easier. Now I have to push the car harder for the rear tires to break loose.
I dont think this bar would make any difference on a stock suspension and crappy tire set up, I would assume the tires would brake loose before the sway bar would even make any difference.
Anyways Im really glad I got this bar.
#513
Hi everyone,
I have been reading that the pro's out way the con's when it comes to the ride feel with the F sway bars. My question is had anyone with lower back problems find this set up to harsh of a ride? Also, wondering how is the ride down the Highway compared to the stock sway bars. I assume it will be more stiff & less lean in sharp turns.
I currently have the stock suspension on my 08 350 and debating if I should install the F-sway bars. If anyone can give me any insight, I would be greatly appricative.
Thanks in advance for your replies.
#514
Hi everyone,
I just put the rear F Sport sway bar on my car recently, and I can tell you it is well worth the money spent. I'm going to drive with it on for a while, and then decide if the front bar will be my next step. So far I'm very happy with the improved steering feel, and reduced body roll, when cornering with just the rear F Sport bar. Hope this helps.
#516
Get your F Sport bars from Sewell Lexus, their prices to members of CL can't be beat!
#517
I thought I would follow up on this question I had:
My front and rear sway bars arrived a few days ago. I'd like to do the install on the next nice day (today would have been a good one - it's 50 degrees outside)
I just picked up Blitz RhinoRamps™ 12,000 Portable Automotive Ramps
(Part No 11905) from advance auto parts. The price for them now is $44.99 - $16 w/ a coupon code.
Suggestions on a good torque wrench to order? any other tools?
You do need a torque wrench.. at first I used a regular ratchet wrench to see if I can tighten it up without the torque, then i decided to use the torque anyway (might as well since I have one
) there was like a full turn and half left till I hit the recommended torque spec for the sway bolts. Soooo you do NEED a torque wrench to tighten up the bolts. fyi I'm maybe 145lbs, but I'm a pretty strong 145lber (just maxed out on bench last Monday 305lbs!
) anyway.. torque wrench FTW!
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#518
Can someone help??
I want to buy the F-Sport rear sway bar only for my 2007 IS350 from Sewell for $200 and have a dealer install it. That way it'll be covered by my CPO and VSA warranties in full.
I just talked to the dealer nearest me and they said it calls for 3 hours to install the rear sway alone at a cost of $345 labor only (!!!) but that it usually only takes 2 hours (!).
Clearly this is absurd, and I told the service person as much when I called. If I had the space and tools (I live in a city and park on the street) I'd do it myself in 30 minutes following the DIY.
But given I don't have the space or tools, and that if I have a Lexus dealer install it then it's covered by warranty, I'd like to have it done at a dealer. I'm even willing to pay a full hour of labor for it, but no more.
Does anyone have experience with dealers installing ONLY the rear sway bar, how long it took and what it cost? I'd drive to a different dealer if they could do it in an hour.
#521
Can someone help??
#522
Here's my update, after driving on my F Sport rear sway bar for the last week. Driving on the rear bar, the car feels more solid at the back in cornering. Cornering feels more precise, not as vague as stock. Body lean in turns is greatly reduced, and my IS is starting to corner like it should have out of the box. The steering feels more responsive, and precise as well. You point into a turn, and it feels like the car wants to carve into the turn. Overall a very worthwhile upgrade.
However, I feel like the front end now is a little soft and less dialed in then the back with the F sport sway bar. I feel a slight imbalance in the car now............back end feels connected and dialed in , the front now feels a little too soft and and allows too much body lean. It's slight, but I notice it. So, I'm definitely going for the front F Sport sway bar asap, as I think the car will really benefit from a bigger bar. Once I get it, and drive with it, I'll post another update.
#523
#524
I've done my research on the forums, and it looks like someone knowledgeable with a lift (like, say, a Lexus service tech...) could install the rear F-sport sway in 30 minutes. To complete my research, I called every dealer within about 60 miles of me to see if any had a better deal, and I was amazed at both how varied their quotes were and how exorbitant the prices were:
LEXUS DEALER / PARTS (price for set) / LABOR (price and hours)
Towson / $650 / $345 (2-3 hrs)
Len Stoler / $495 / $173 (1.5 hrs)
Sheehy / $495 / $238 (2 hrs)
Silver Spring / $725 / Didn't quote
Rockville / $744 / $257 (2 hrs)
Chantilly / $495 / $340 (3 hrs)
Alexandria / $700 / Didn't quote
Just thought I'd share how varied these quotes were. I figured because they're all Lexus authorized dealers buying the parts from the same place (Lexus), they'd be about the same. Unfortunately, given I just spent the cash on the car, I don't have ~$700-1000 to spend on getting one sway bar purchased and installed. From what I read on the forums, I was hoping to do it for more around $300 ($200 for the bar and $100 for install).
Anyone know of a place in the Baltimore, Maryland (or greater Maryland/DC) area that would install the bar for me if I bought it from Sewell? (And I know that this would then not be covered by my CPO warranty, but I've accepted that given the prices above). I'd be hugely grateful!
