Official F-sport Sway Bar Thread!
#541
Thanks for this info. This past Friday when it was 70+ degrees, I thought it would be the perfect day to put both the front and rear sway bars in my '08 IS 350. I attempted but I couldn't even get the bolts off. The next day I had my alignment scheduled at IAG Performance in Westminster and I also asked them to give me a quote on the sway bar install. They said it would be $240 - $80 an hour for the mechanic, 1.5 hours for each bar.
I thought that if I Couldn't do the install myself I'd have them or someone else do it. I'm heading on vacation for a couple weeks this Thursday. I'm thinking of scheduling the install now (I believe they're usually backed up) and when I come back, trying it again, and canceling the appt if I can pull it off.
I haven't put my engine under covers back on since I pulled them off on Friday. I hope I don't damage anything. I just have one more day of driving tomorrow and then the car's parked for 2 weeks
#542
There is something I did want to ask the forum though - would dealer be ok for the sway bar install? Because looking at price quotes by calvin2376:
LEXUS DEALER / PARTS (price for set) / LABOR (price and hours)
Towson / $650 / $345 (2-3 hrs)
Len Stoler / $495 / $173 (1.5 hrs)
Sheehy / $495 / $238 (2 hrs)
Silver Spring / $725 / Didn't quote
Rockville / $744 / $257 (2 hrs)
Chantilly / $495 / $340 (3 hrs)
Alexandria / $700 / Didn't quote
..and assuming 1) it's for both the install of the front and rear sway bars and 2) ok if you buy the sway bars from elsewhere (I already grabbed them both from sewell using the clublexus.com discount), $173 doesn't seem too bad.
IAG Performance, the place that did my alignment last saturday, said it was 1-2 hours (or was it 1.5 - 2hrs per bar) at $80 an hour making the cost anywhere $160 to $360. If it's not a big deal for the dealer to do this, I'll just go with them. Plus, I wouldn't feel bad canceling the appt right before if I can get the install done on my own versus with this friendlier performance shop
#543
I didn't want to take this thread too off topic so I posted you a visitor message. If you want, maybe we can get a thread going in one of those regional forums if anyone else wants to join.
So if you're looking at those labor quotes and wanting to know what it would cost to do both front and rear, double those labor costs (I know, it's ridiculous).
That's why I'm all about either doing a group install during a meet on a weekend or something, or maybe trying to get a group discount at this IAG Performance place.
#544
And I would hope that IAG shop is quoting 1-2 hours for both bars because if they can't do both bars in under 2 hours with a lift and air tools they're completely incompetent.
Me and a buddy did both in just over an hour... with jacks, jackstands, and hand tools. And only 15 minutes of that was the rear bar.
#545
Do you have to have a torque wrench to do this install? They are like $70 at Home Depot, and I will likely never use it again.. add in another $50 for rhino ramps, and I might as well get it installed at a shop and save myself the effort..
#546
No.
To do it properly? Yes.
You can just hand tighten, but you've no idea if that's the proper amount of torque (it's almost certainly not... and no idea if it's too much or too little).
I think some auto parts places will lend tools, check if they do torque wrenches.
As for the ramps- this'll be like the 5th car I've used my same set of rhino ramps for- those things are awesome... and they'll let you install an axle-back exhaust in 15 minutes yourself if you want to later on.
#547
like I said, I'm going to give it another go first before giving up and having a shop do it
Edit: gave it another go and couldn't do it. Heading to shop later today to do it. Here's a write up w/ pics: http://shahryar.net/2011/03/14/faile...y-2008-is-350/
#548
I have an 06 awd. so i just got my rear sway today. On sewell i just ordered the rear sway alone. Theres no option for awd or rwd but i wasnt sure if they were same. Well the box says is250awd on it. So if any one is wondering they still have those same ones. and they are the same. I dont know where someone got the info that f-sport made new rear ones specifically for awds.
#549
Up until '09 The sway bar kit for the AWD IS250 was PN PTR02-53080 and consisted of only a rear bar. It was the same rear bar that came with the front/rear bar kit for the RWD. It was a 19mm solid bar.
In '10 Lexus dropped the prior AWD rear bar kit and replaced it with PN PTR02-53096 and this kit consisted of a front and rear bar. The dimensions are 30mm in front and 17.5mm in the rear.
Again, we are talking two different kits here. I have attached a chart to explain this.
Lou
#550
So if you dont order the AWD "kit" which consist of the front and a 17.5mm dia rear, you can still order the 19mm dia rear bar ALONE which STILL works for both the RWD and AWDs correct?
OK I'll try to put this comment into prospective. It's been discussed before, but here it goes again.
Lou
Lou
#555
