So I just received my F-Sport sway bar. I ordered the AWD sway. I thought all the rears F-Sport sways where the same? Then I read the above quote about the F-Sport sways for the diffrent models. Is the above poster correct?
Yes, I am correct. Up until 2/27/08, the F-Sport Sway sold for the IS250 AWD was the 19mm bar from the ISX50 F-Sport kit for the RWD Models (Which you apparently have). On 2/27/08 an new kit for the AWD model was made available that is different than any other F-Sport kit, and has a stiffer front bar, and a smaller rear bar. See PDF attached. You are OK, if you have an IS350 RWD.
otherwise ordering through the dealership, or somewhere like sewell parts online will be the 495...
Originally Posted by Juice14
What's the best price for just the rear sway bar for IS350?
as far as purchasing them separately, through dealerships and online for the 250rwd and 350 they come as a set, and you cant order them separately as far as i know...
the awd spec bar only comes as a rear, but even im still a bit confused with regards to the difference, but the question has been asked many times and im sure theres an answer in the forum somewhere
just order from sewell , like i did, u only need the rear only for is350, so ordered AWD rear sway bar that would do it , its like less than 200$ included shipping, its totally worth it, since your car its lower too lolz, awesome ride
thanks man
I thought the rear AWD and the RWDIS350 sway bars are different for 2009?
the AWD is rear is 17mm and the IS350 RWD is 19mm
