IS F front rotors
#212
So I'm fairly certain these will fit under my 18" +42 GT-C's, but from the sounds of it they wouldn't fit under Supra TT's? That's the only thing holding me back from doing this mod, since my TT's are my winter wheels. Unless someone can prove me wrong?
#216
Based off some research it seems that 1 piece type 18in wheels (TE37 typre stuff) will fit over the IS-F brakes. Supra front wheels wont fit the front brakes. Rears should be ok though?
#219
#220
Are the ISF calipers the same size as the Z06 ones? They're pretty beefy and the challenge seems to be not in the diameter but the clearance of the spokes. I've always had the CCWs which clear by a good margin but I've never seen ISX50 wheels off the car. I measured my setup for a member a while back and the distance from the rotor face to the edge of the caliper is right at 2 3/8" and the distance between the rotor face and the hub mating surface was 1.25" so if your wheels have ~1.25" clearance between the mating surface and the back of the spokes, you should be ok.
#221
#224
Has anyone tried to fit the XXR 521s over these guys yet?
*edit* before anyone bashes on XXRs, I like their cost factor and the fact that I won't flinch or think twice when they get dinged up or curbed.
