IS F front rotors
Old 11-15-08, 12:56 PM
//LRD
//LRD's Avatar
Originally Posted by sTcT300
oh man i cant wait to see this
I can't wait to show you the step by steps
Originally Posted by 5sp_jzz30
how much are the is-f rotors?
200.00 each and I'm sure in the near future some comp.will make them cheaper
Old 11-15-08, 01:06 PM
LexFather
Guest
Posts: n/a
the rotors were $200 each? I find that hard to believe. The reason the GB never materialized was the initial price was I think 1k front and 1k rear which pretty much became 1k per rotor/caliper.
The Rotors are by Brembo as the entire system.
The F-Sport rotors are the same size but actually true 2 piece brakes, with an attaching hub. The IS-F 14.2" brakes for instance, are solid 1 piece.
Good luck on the project!
Old 11-15-08, 02:02 PM
SATXSC400
SATXSC400's Avatar
I believe that price was his "hook up" price from his friend at the Lexus dealer. Can't wait to see the pics and write up LRD.
Old 11-15-08, 03:54 PM
//LRD
//LRD's Avatar
It's a one pc rotor call any Lexus dealer and you find them for 249.00 each retail price.I paid wholesale.
Old 11-15-08, 04:09 PM
//LRD
//LRD's Avatar
Thanks man I'm going to try to mach them up this Sunday and post some pic's.I'm just worried about the 18in GS wheels clearing the rotors.And I still have to make the brackets.
Old 11-15-08, 04:29 PM
YeA 2jZ
YeA 2jZ's Avatar
Does the stock IS=F rotor you buy from the dealer already come cross drill????
Old 11-15-08, 04:39 PM
One HoT
One HoT's Avatar
I would be extremely interested to see how the LS caliper which was designed for the LS rotor would fit a much bigger 14" rotor from the IS-F..
Do you think you need to change out the brakets and mod a new bracket to acccomadate the much larger rotor?
I'm guessing that the OE bracket will not bolt on after you install the IS-F rotor...Whatever might be the case, I hope your install goes well!
Old 11-15-08, 04:45 PM
GSteg
GSteg's Avatar
He already said in this thread that he's having adapters (brackets) made.
Should be interesting to see the results
lexforlife
lexforlife's Avatar
it will sit high up on the rotor .. it can work and will look hot but ? is will it work effectively sitting so high up on the rotor
rem guys i did the first rear bbk oem kit for the gs400 a couple of years ago using the rear rotor and caliper from the new ls430 whch were huge ... had brackets made , everything mounted up but the caliper sat too high on the rotor for it to be effective there was about a 1in gap so although they looked great , it failed to produce the desired results
but hey good luck on project , look forward to seeing urs come off successfully
Old 11-16-08, 09:19 PM
//LRD
//LRD's Avatar
For those who wanted to believed that this project will work I thank you.
Old 11-16-08, 09:25 PM
GSteg
GSteg's Avatar
Looks great!! Any difference in pedal feel?
Old 11-16-08, 09:29 PM
One HoT
One HoT's Avatar
Looks great..! Glad it worked out...
Did you happen to take any pics of the custom made bracket? I'm curious to see how it bolted on..
Old 11-16-08, 09:34 PM
//LRD
//LRD's Avatar
Sorry guys that is a really bad picture. So here's another and I'll post more pic's tomorrow.Finished kinda late.
It's late here so I'll do the step by step tomorrow.And the 18 gs wheels won't work so I can't install the rotor's untill I get my 20in Savini's
Old 11-16-08, 09:45 PM
//LRD
//LRD's Avatar
Thanks guys this is still just a mach up.I have to put everything back tomorrow.The 18 Gs won't work.I'll be able to let you guys know how the brakes feel in a few weeks.
member this isn't the finish bracket.It still has to be made
Old 11-16-08, 09:47 PM
chrispy
chrispy's Avatar
Looks great! You should have a few extra brackets made for anyone who wants to do this mod.
Quick Reply: IS F front rotors
