I need help!!!!
I need help!!!!
sup CL members. i have a 2000 ls400 front brake calipers and was wondering if it will fit onto my 92 sc300. and would i have to change any brackets of anything like that.
direct bolt on, but you still need ls400 rotors.
Use same brake lines but need the 2 bolts (4 total, 2 on each side) that hold on to the caliper of an ls400. Since the sc brake bolts are too long, they get way too close to the rotors. Either you
a) cut the bolt and make it a little shorter or
b) go to the dealer and order 2 bolts (4 total, 2 on each side)
i'd choose the lader. anyways... i wont be nice next time, search!
Also, One thing that has rarely been mentioned, the top mounting portions needs a little grinding just under the bolt hole as there is slight interference in mounting it on the bracket. Again, just a little grinding, but nothing the basic mechanic can't accomplish. Do a search on it and there is a detailed pic on where to grind it.
Oh and don't forget your pads too
