front shocks/ struts install
i just purchased a new set of shocks for my 1992 SC and i already install the rears, the front ones seem more complicated to install, whats the easiest way to install them? sorry to sound like a noob. thanks in advance for any help.
i had a hard time removing my fronts also when i switched to the tein ss suspension. the easiest thing i found that will give you more room to take them out is to remove the sway bar end links from them the lower control arm. that will give you more room to move the LCA up and down to wiggle out the shocks. while your down there might as well change the endlinks, theyre only a few bucks a piece if your stock ones are messed up. Hope this helps you , good luck.
GX470GT
05-17-11 08:30 AM
