which sway bars?
Old 05-24-10, 01:52 PM
  #31
Blkexcoupe
Blkexcoupe's Avatar
Originally Posted by fenderub
thought i would bring back this thread, rather then make a new one.
i think im going with whiteline sway bars. 30mm front and 20m rears [comes with its own urethane bushings]
they were made for the mkiv supra, and so all i would need is the rear subframe mounds for the mkiv supra. correct?
what about the brackets that hold the bushings?
Yeah, you will need the supra sub frame mounts to be able to bolt the Supra sways on to the car.
The brackets that hold the bushings should come with the sway bars since it has to match the diameter of the sway bars + bushings.
Old 05-25-10, 10:22 PM
  #32
RedPhoenix
RedPhoenix's Avatar
I just bought whitelines... ill let you know how they are soon enough.
Old 05-27-10, 04:45 PM
  #33
BigWaveSC
BigWaveSC's Avatar
Originally Posted by itazura
largus and doluck also made for sc.
both are discountinued and both are ones i want to buy.
anyone have any used do luck's?
Old 05-27-10, 04:50 PM
  #34
t70 supra
t70 supra's Avatar
i got thier stb is bad *** but try dusty @ mvpmotorsports he cool with the do luck rep.
Rock-a-Lex
Suspension and Brakes
10-15-13 09:10 PM
Altec914
11-18-07 12:05 PM
pilip99
09-17-05 12:21 AM
pjfernan
15
06-17-05 09:51 PM
sc400
07-01-03 06:17 PM
Quick Reply: which sway bars?
