audible "clunk" noises from floorboard area, especially when turning or backing up
Old 11-23-08, 08:31 PM
istundra
istundra's Avatar
Question audible "clunk" noises from floorboard area, especially when turning or backing up
Hello,
I was searching on the Daizen and found a product that seems like it will address my issues.
Please see link:
http://www.daizensporttuning.com/pro..._bushings.html
I am aware that our lower ball joints may require to be replaced through wear and tear. My 2003 GS300 has about 35K right now on the clock.
Will this product fix my problem? Any other substitutes or comparable solution?
Thank you
Old 11-23-08, 09:55 PM
kit cat
kit cat's Avatar
without knowing what the source of the problem is, swapping out bushings would be shooting blindfolded. Have you tried jacking the car up and checking your suspension?
Old 11-23-08, 09:57 PM
istundra
istundra's Avatar
no i have not, but i have had this problem as young as 15K. I am unsure if it is normal, but i have lived with it since then.
The issue was brought to Lexus when the warranty was still valid and they said it is normal. i am unsure if Stevens Creek Lexus service was completely honest with me.
Old 11-23-08, 10:07 PM
kit cat
kit cat's Avatar
if it's an audible clunk when turning and backing up, I highly doubt it is normal. Not sure if you're car is still under warranty but have you tried another dealership?
Old 11-23-08, 10:26 PM
istundra
istundra's Avatar
it has expired already and have not tried another dealership....
Old 11-24-08, 11:14 AM
LiLS
LiLS's Avatar
i got the same noise, so im changing my balljoints
Old 11-25-08, 07:18 PM
istundra
istundra's Avatar
keep us posted if that fixes the problem.
Thank you
Old 11-30-08, 10:26 PM
skperformance
skperformance's Avatar
daizen site has not been updated since 2005 it looks like, any idea on where you might be buying the bushings.
I plan on changing my front lower strut bars on my 03 430.
Prices and places anyone ?
Old 12-01-08, 12:12 AM
Vincent123
Vincent123's Avatar
i have clunk noises from the rear of my car too. no clue as to what it is.
Old 12-01-08, 01:22 AM
japspec
japspec's Avatar
Check the bolt for the rear trailing arm that goes thru the bottom of the coilovers if the bolt isnt tight it will make that clunk noise. Let me know if it works.
lensf415
09-25-20 10:39 AM
NaijaRx300
RX - 1st Gen (1999-2003)
14
11-07-10 08:39 AM
Cwall
Suspension and Brakes
11-26-09 03:53 PM
dat-is350
02-07-09 04:06 PM
salvatore
06-25-06 08:32 PM
Quick Reply: audible "clunk" noises from floorboard area, especially when turning or backing up
