SUPRA upper CA with camber adjustment fit sc300?
so after countless weeks of calling TM engineering i have given up on getting my camber kit as they never respone to emails nor pick up their phone and there voicemail is always full WTF!!!!!!!!!!!!!!!!!!!!! so i am going another route but before i buy i jus wanna make sure i have the right part i called lexus and got the stock part number for sc300 99 upper CA #48630-29046 and then called toyota to cross ref the part number they came up with 1996 Supra upper CA so with that in mind would it be safe to say if i order a upper CA for a MKIV suppra with camber adjustment it will fit my sc300 im tired of replacing half used front tires from negative wear and really want to fix this before i dump another 400 for front tires
more info i called TAP in rancho cordova and tlk to my buddy over there they said there was 2 different upper control arms made for the MKIV the first was until june 96 then changed to the version 2 july 96 up to 98 which is compatiable
