Replacing OEM rotors and pads on IS350
Anyone noticed that the lexus rotors appear to be backwards? The one labeled L would imply putting it on the left side but the vanes are then leaning forward trying to pump air towards the hub. This contrary to any directional vented rotor I have seen. Anyone know something about this oddity?
^You're not the only one that noticed that. I actually did some research and got ahold of a technical guy at PowerSlot and we talked about the rotors and their design. Basically it boils down to the way Lexus design the braking systems in these cars and the rotors' vein patented design. It is backwards to the conventional, but it works...and works well. I posted all of my findings on someone's else thread, so I cannot really find it now.
EDIT...found the thread under the phrase "vein design"!
https://www.clublexus.com/forums/sus...nt-rotors.html
Am i the only one that is having problems with lexus rotors? They were squeaking so dealer replaced the for free then they got warped because we were hitting the brakes at 120 mph so hey resurfaced them but now they are shakng again. Anyone have idea, maybe stoptech slotted rotors next?
Tech Info Resource
Read this.
http://www.stoptech.com/technical-su...nd-other-myths
Yes, you are the only one sufficiently abusing your brakes to cause the problems you are having.
we have a very unique offering of customizable OE fit, plug n' play rotors...
our storefront has your application's pricing & options loaded!
have a look here: www.adamsrotors.com/store
if you have any other questions, please let us know via email!
thanks
-a
thanks
-a
