Daizen grease substitute
Old 12-05-08, 05:42 PM
damon
damon's Avatar
Default Daizen grease substitute
I have an LS but this seemed to be a better place to ask.
I beleive the grease from my Daizen Sway Bar bushing upgrade needs to be re-applied.
Can I get the Daizen grease or is their a substitute that will do a better job?
thanks!
Old 12-05-08, 07:51 PM
aquanuke
aquanuke's Avatar
Ive heard marine grease works well. Mine are starting to squeak abit as well. The Daizen grease does not last that long.
Old 12-05-08, 10:39 PM
Alexus_300
Alexus_300's Avatar
I've used Super Lube and that has lasted for quite some time now. I believe I haven't relubed my bushings in over two years.
Old 12-06-08, 12:10 AM
damon
damon's Avatar
I love options. Keep the info flowing!
Old 12-06-08, 01:18 AM
skperformance
skperformance's Avatar
ANy performance store stocks small packets of silicone lube . It is made to not break down and stay pliable in cold.
Energy suspensions make the same stuff and it is universal
Old 12-07-08, 11:22 PM
Ddot808
Ddot808's Avatar
if you are using poly bushings do not use silicone based grease, it deteriorates the bushing. use a graphite based grease. Napa or autozone should have some
Old 12-09-08, 10:24 PM
Scott1258
Scott1258's Avatar
Add some anti-seize paste to the grease that you end up using. this stuff stays put forever I hear (I have it on mine and no squeaking at all). I too used the energy suspension grease - it's designed specifically for poly bushings.
Do a google search on anti-seize paste and poly bushings and you will gets lot of info.
Another option is to switch out your daizen sway bar bushings for energy suspension ones that have a grease nipple to just grease them every time you do an oil change and you'll never have a problem with squeaking. I did a whole write up on my squeaking daizen sway bar bushings - search for it and you'll get more info.
Hope this helps!
Scott
Old 12-12-08, 08:15 AM
damon
damon's Avatar
Thanks Scott. That is a great idea!
Nobody303
Suspension and Brakes
27
09-18-11 09:16 AM
mark98ls40
07-19-10 09:30 AM
Grover
03-02-06 06:14 AM
lex400sc
25
05-28-03 10:44 AM
Quick Reply: Daizen grease substitute
