I know they should, since both have the same bolt pattern on the hat, but the springs are different, so I just wanted to see if anyone knows and is sure of this.
hahah so the way i see it...you can use springs stock or aftermarket from a supra for a sc as long as you use the stock hats? Same goes for shcks and struts?
To clarify my yes, you can use either the supra top hats OR the SC top hats with your supra springs and shocks or sc springs and shocks.
To clarify that further, you can use the supra top hat on an SC and an SC top hat on a supra. You might even be crazy enough to mix and match! OH NOEZ!!!11!1
The thing to remember is that if you are using supra springs, you MUST use supra shocks. You do not want to use SC springs on supra shocks.
