Umnnn...How do I install this "SPC" Camber kit?
Old 12-09-08, 06:29 PM
lexusscturbo
lexusscturbo's Avatar
Default Umnnn...How do I install this "SPC" Camber kit?
How do I install the SPC camber kit?
Its instructions do not make any sense to me
Old 12-10-08, 11:42 AM
lexusscturbo
Nooobody???
Old 12-10-08, 12:44 PM
SorrGwa
SorrGwa's Avatar
http://www.spcperformance.com/PROD_D...d2=67510&cmd3=
THese ones??
Fairly easy if u got the dye grinder with the grinder bit that is straight, for the rotary dye grinder. probably 3/8inch bit size. ( i dont remember)
something that looks like this dye grinder, borrow one if u can http://www.homedepot.com/webapp/wcs/...10000003+90401
You remember the stock camber adjustment bolt. this is the bolt on the lower rear arm, closest to the wheel. it will look identical to the spc bolt with the offset metal circle.
with the arm lowered, u use the dye grinder to elongate the horizontal hole. the spc basically is a larger diameter metal circle, which allows for more camber adjustment (about 1 degree). how much to grind away? use the metal bracket that the spc bolt sits in. its also got the elongated hole. just grind a bit until u get about the same amount. you will also notice that the spc bolt is longer, this is because the metal bracket it comes with cups the outsides of the lower control arm. install the new spc camber bolt, and get an alignment done
it should take no more than an hour, depends on how sharp ur grinder bit is.
Old 12-10-08, 02:26 PM
lexusscturbo
So a dremel will not work?
Old 12-10-08, 02:32 PM
sakataj
sakataj's Avatar
with tools......
j/k.
Old 12-10-08, 04:49 PM
SorrGwa
SorrGwa's Avatar
a dremel is essentially a rotary dye grinder.
i just used the airtool version of it with the 3/8inch bit. worked fine. managed to pull my camber in to -1.2 degree with the wheels sitting flush
Old 12-11-08, 08:39 PM
lexusscturbo
SorrGwa what are you lowered on?
Old 12-12-08, 04:12 PM
SorrGwa
SorrGwa's Avatar
tein ss coils.
i cant say i know how much i lowered, but its enough to have it flush. so for the back, at least 2in.
Old 12-16-08, 06:01 PM
ShaneC
ShaneC's Avatar
why would you want to correct camber
Old 12-16-08, 08:24 PM
lexusscturbo
Shane its a DD not a "show car"
Old 01-02-09, 08:58 AM
lexusscturbo
SorrGwa might you be able to take pics of the way the bracket sits? in the LCA?
Old 01-03-09, 01:28 PM
SorrGwa
SorrGwa's Avatar
ill try to later, the cars been sitting in the garage for the past month as we got a huge dump of snow. the snow tires are no match for 2ft of snow, dont feel like plowing or being
Old 01-03-09, 10:14 PM
PHML
Master Thread Closer!!
PHML's Avatar
I would be hesitant in making the lower arm hole larger.
Old 01-03-09, 10:18 PM
jcat_350
jcat_350's Avatar
+1, if it was anything but a stamped part i wouldn't worry, but doesn't seem like the best idea.
Old 01-14-09, 06:35 PM
lexusscturbo
Anyluck on pics?
Quick Reply: Umnnn...How do I install this "SPC" Camber kit?
