tighter suspension
tighter suspension
at the moment I hipermax coilovers but yet it does not fulfill my suspension needs..but I also want the steering wheel to be quite tighter as well what would be the next reasonable upgrade? THANKS
this is what most people use instead of rubber (could be the same as polyurethane)
http://www.nolathane.com.au/
and have a good chat to a suspension place about circuit racing suspension modifications, alignments, toe and camber etc.
Yes very much so.I have one blow shock now but if i had some type of coilover or lowering springs with good shocks it would handle like a motherfu#ker.
I bought prothane bushings for my car.But they were a pain in the as# to do.Sense the bushings were 1 or 2 millimeters bigger than the hole you had to put them in.you have to press them it with a vice or a hydraulic press.But it is well worth it in the end.
Before it had so much body roll and now when you turn a corner it doesn't have much body roll.If i had better shocks i would really have no body roll.
Prothane bushings = Tight suspension
I highly believe that the flywheel will have no use for me due to the fact that when under hard driving im the type of driver that rev mathes quite often thanks though.. high rpms= love
