Tom's Advox installed! sc300
Before
After
Does anyone know why my rears are too high up??? I lowered as much as possible already... It came from a supra so maybe is that why? Cuz the supra has huge tires in rear?
After
Meh a little high. Did you just install it? if so give it a couple of weeks for the springs to settle in and it might lower the rear a little more...
edit: hah beat Kaydee to it!
rub a dub dub...please come back with a thread asking why your radio and wipers stay on when the car is off. lol
reroute the chassis harness on the driver side inner fender well.
let the springs settle. do you have the pictures of the suspension out of the car? is the shock body itself threaded and goes into the lower mount or is the shock threaded and it has the spring perch on it. i dont think that sounded too clear. sorry.
wow that is low lloyd, you might want to lift it up a bit til the rears follow that front drop. give it a week or so. it looks awkward right now but will look good later on. and yeah, my homeowners assoc. is still clueless where all the oil came from that day you bird killer
since you cant turn the shock body be careful how much you lower the car. you are effectively shortening the shock travel which, if done to the extreme, can cause it to bottom out and be damaged as well as really crappy ride quality.
how are the tom's coilover anyways so far?
LyFeWoRx
Suspension and Brakes
13
11-03-10 10:26 PM
