IS350 Brakes on IS250
Has anyone done this conversion yet? is it a simple swap with just the brake calipers and rotors?? does anyone have the part numbers of the parts i need just to do the conversion. Thanks!
Check out Sewell's website..it IS a direct swap with no modification needed. The kit cost about a grand. http://www.sewellpartsonline.com/par...l.asp?id=89403
vedy nice.. i thought the rears were the same for the is250 and 350? do you guys think it would be worth it to change the rears also? im going to order the fronts right now!
Before you order the fronts, put in the promotion code "CLUBLEXUS" I think you get a pretty good discount w/ that code. Pretty much takes away shipping costs. And no, the rears aren't worth it. Spend that money on some stainless steel lines and some really high-end heat-resistant paint to paint your calipers whatever you like.
If I buy this kit will I need anything else besides buying rotors. I want to get slotted rotors and SS lines from someone else.
http://www.sewellpartsonline.com/par...l.asp?id=90038
Woowee
04-19-13 12:30 PM
