TSIB Brake Pads
I use "..." ....... a lot
Same here.
Not necessarily true. "bite" refers more to brake pad FEEL, not PERFORMANCE.
but I'll agree that tapping the brakes doesn't jut you forward like it did with the original pads. I like it though. It makes the car much more predictable and controllable.
It's just like warranty coverage--warranties dont cover normal wear and tear. If your pads are at the end of their useful life, the dealer may say it's not covered.
Absolutely untrue if you're talking about stopping distance.
Brake pads can't change stopping distance.
As noted they can certainly change the "feel" of the brakes, and in this case for the better, but the car will stop in -exactly- the same distance, just as physics requires it to, using any set of brake pads capable of engaging ABS.
Well I'm going in tomorrow to get it and any other recalls done hopefully get some new rotors too, seems like that is case by case basis.
Tech Info Resource
^^I traded-in my IS350 with 59k miles on it and still on the TSIB pads with LOTS of meat left. I put them on at 21k. It's all about how you use brakes.
Tech Info Resource
Are you sure about that? Since we don't often engage the ABS the pads will stop differently based on the friction they are able to produce-this is different for each type of pad. Come to think of it, the ABS will also be limited by the different pads and subsequently stop at a different distance. The low dust pads are perfectly fine for most of us and I'm extremely happy with the change. The "feel" is your indicator of how fast you can stop. The high dust pads could stop pretty much on a dime-great for the track and that's about it. Just my $.02
Read this. The author is a world renowned expert on braking systems and stability controls.
