i want air rides
#31
#32
I am in the process of buying all of my air-ride stuff also. I have decided I am going UAS, but are the Aerosport bags offered in 3/8 ports? I don't want 1/4 inch... too slow
Also, what is a water trap? (I can assume what this does by what it's called) And where do I get one?
Quincy
Quincy
Quincy,
Unfortunally we have the largest port that is able to be put in the bag. With the inner chamber there isn't much room between the inner/outer bellows for an air port. You will be surprised, it will move very will with 1/2" line going into the 1/4" ports.
#33
Here is a Video of an SC.
http://www.youtube.com/watch?v=Oe1du...e=channel_page
#34
What's airride's website? http://airride.com/? I couldn't find the pod you're talking about.....![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Edit: pic didnt work
#36
How about the top mounts and stuff? I don't the the stock stuff that I can mount? like the rear that I saw we need the upper cover and mount and cut it a bit to fit the hose, but I don't have it....
#39
![](http://www.trademotion.com/schematics/8/8909460.gif)
So I'll need: 24,21,19,23,17,22,20,18,15,7
![](http://www.trademotion.com/schematics/8/8909225.gif)
and 10,14,15,16?
.... That came to 852.48...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#40
you will be surprised... I actually have customers that are running 5/8" Inside Diameter line into our Aero Sport. My understanding is that its kinda like a fire hose, they run a large line and then reduce it down. By stepping it down for that very short distance it will increase the velocity of the air.
#41
18, 20, 22, 23, 19, 21
Front:
15
Then pick up a set of KYB struts from your local auto parts store.
#42
That's just regular air because twards the end of the video you can see how its running out of air.
#44
Air-Zenith is a world class manufacture for air ride air compressors and accessories. All-New AZOB2 is 200PSI Working Pressure, 100% Duty @ 200PSI, 3.5CFM Air Flow, Moisture and Dust Resistant, Oil-Free Design, comes standard with 1/2 stainless steel braided PTFE air hose with inline check valve, waterproof cooling fan, air filter, Nylock self-locking mounting hardware, 80A relay with relay socket and Industry's Leading 2-Year Warranty!
www.Air-Zenith.com![](http://www.air-zenith.com/products.asp?cateid=28&id=52&expandable=0&menuid=2852)
www.Air-Zenith.com
Is it safe to say the 3.5 cfm is at freeflow? What was the tested voltage? Also what is your maximum amp draw @ what voltage and what psi?
#45
3.5 CFM is at free flow (0 PSI), 100% duty cycle rated at 200 PSI, supplying voltage is 13.8volt, max. amp draw for the ALL NEW OB2 BLACK is 35A at 13.8volt at 160PSI.
