Aftermarket Sway End links...front and rear
Pete, I've finally taken a look at these sway end links and it looks good. While I know that they are much stronger than the OEM ones, my biggest concern is the heim(sp) joints that is used to replace some of the rubber bushing. These heim joints are used mostly on race cars and I have a set on my supra but they make alot of noise. So I'm thinking that it will definately be noisey for the GS don't you think?
Master Thread Closer!!
That's my concern as well...thats why I wanted to test them out first once I receive them.
Same here Pete, that was my concern as well. No doubt it will be a little noisier than rubber. I need new end links as well soon and I might just end up getting OEM or the ebay ones. If after you test them out it turns out to be quiet, than I'll grab a set off you, but I'll let you test them out first
