Air Suspension Bracket QUESTION!! HELP**
#32
I'm sure you've seen it before --> Click Me
I have never seen before... thats awesome!!!
#33
#35
not to turn this thread into a youtube extravaganza .....but i hope to achieve a look similar to this LS
http://www.youtube.com/watch?v=2VD-e2jySiQ
#36
Not to hijack the thread, but I'm looking for an air suspension just for my fronts (to lower and raise on speed bumps, steep driveways), but i'm concerned that the ride will be too floaty. Also, I plan on tracking the car. Do you think i can use the universal air suspension?
I'm trying to do this on a budget as well.
#37
#38
The "cheapest" way to do the system and still have it lift/lower would be to use a single compressor, with 2 dump valves, and 2 check valves. You can have it where when you put the switch up, it will turn on the compressor to fill the bags, and push it down to drop it.
now, it will take some time to lift, aprox 5-10 sec from a drive height, to an extra height, but, you won't have air transfering from one side to the other giving you the same handling as a full system will.
