NEED HELP!!! GoT a Clunk Noise Coming from Passenger Susp.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
have a 99 GS 300 w/ 109k stock everything.. with 01 GS430 17 chrome wheels.I need yall help.. tell me what you think would be a cause of this clunk noise..
< I would put it in reverse and go back and then stop and put it in drive and go forward and then stop quickly and there would be this loud "clunk" noise..
Had just bought the car about 3 months now and it has new front and rear breaks, timing belt, water pump done by previous owner. >
if anyone has experienced any type of problems.. please let me know.. I've seen pictures of previous clunk noises.. It wasnt too pretty. any suggestion please PM me, Thanks
GSteg is going to tell you that it's your brake fitment hardware (spring clips).
If you don't hear a clunk after the first clunk after changing FWD/REV or REV/FWD and braking, don't worry about it. The clunk is not going to destroy your car, it is just the brake shifting slightly from forward to reverse.
but next time you do your brakes, replace the brake spring clips as well. A mechanic would charge you full price of another brake change, if you wanted to change it now.
OEM part would be called the "brake fitting kit" or fit kit
Sounds like brake pads moving a bit if it only happens under the conditions you described. This is pretty normal for the GS. If you post it in enough forums, it may eventually go away on its own.
https://www.clublexus.com/forums/sus...need-help.html
it happen after i hit the breaks quickly.. so raytseng, it would be normal then? i dont know about that one. i drove my friends 99 gs400 and it wasnt doing it.. i dont know but im thinking its a bad thing tho. it alway happen after i go in reverse then drive, it happen when i first hit the breaks, then on it would go away until i start the car back up again or when it gets cold...but thanks for the info... any more suggestion???
Did you completely read my post? Suggestion has already been given.
If you are worried and want to fix it, change the brake fit kit, then report back. Your friend's brake clips may not be as worn as yours or have been previously replaced sometime before.
Based on what is described and prior cases, this is not something that to be worried about in a Toyota brake system. If you feel differently, what else can we say to convince you? Go to a mechanic who actually can look at your car rather then some yahoos on an internet forum if you have already made up your mind that it's a "bad thing"
Took it to toyota on monday and got a oil change and alignment done.... ask them to check out my clunk noise... said everything looks good.. took it back to them yesterday again.. car been there since.. havent heard from them yet so? =(
i guess im shooting for a break kit 1st... we'll see
just spoke with the toyota dealership about my whole problem.. quote
tech: "We took the tire off, checked everything out.. everythinsg tight and your brakes are about 90 percent, fairly new.. cant seem to find a thing wrong with it.."
me:i said, okay what am i suppose to do now..
tech: get a second opinion?
me: wtf i said to myself... this is bull shiet especially from a dealership![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
i guess imma just get a second opinion tomorrow....
Everyone's telling you the same thing. The only "bull shiet" is your lack of comprehension.
The "clunk" is normal for the way Toyota brakes work.
Again, if it bothers you, don't play stupid. Just tell the mechanic you want the brake hardware clips/springs changed to new ones.
If he's an honest mechanic he'll tell you it's not necessary and you're wasting your money, but it's your money to waste and customer is always right. I guess that's better then you wasting everyone's time and over and over again asking the same question.
GS300ToM
01-14-09 01:23 PM
