drop with tanabe, too much negatice camber
Old 01-17-09, 11:06 PM
nokcy21
nokcy21's Avatar
Default drop with tanabe, too much negatice camber
i dropped my car with tanabe df210, love the drop,but when i did my alignment theres too much negative camber in the front. and some on the rear. and i search for some camber kit and there kinda pricey, so i was thinking about putting it back to stock. any suggestions where to find a good price for camber kits? thanks
Old 01-17-09, 11:16 PM
VIS250P
VIS250P's Avatar
Dude, why u worry about tire get mess up from the camber sit way off.. Stick with it.. Quit thinking negative and there are many aftermarket camber kit everywhere..
Old 01-18-09, 12:51 AM
AYEmike
AYEmike's Avatar
i would only worry if i had -5.0 in the front. With the tanabe df210s springs not cut, you should get under -2.5.
Old 01-18-09, 12:58 AM
VNN326
VNN326's Avatar
forsure, your not that cambered if your dropped with springs. SLAMMED on coils is another story.
Old 01-18-09, 02:22 AM
ShaneC
ShaneC's Avatar
dont hate camber.. camber is your friend as you lower your car. hahaha
but if it bugs ya.....
doesn't exact have the RCA stuff that correct camber?
Old 01-18-09, 07:36 AM
GSteg
GSteg's Avatar
RCA doesn't correct camber on springs. If anything, it will most likely add more negative camber. The front will be dropped so low while the rear will be high up in the air
Old 01-18-09, 10:05 AM
chrispy
chrispy's Avatar
Rear RCA's can correct camber on springs, but front ones can't unless you have coilovers. But it doesn't add camber, so you get more drop for free!
Old 01-18-09, 10:08 AM
phillygs3
phillygs3's Avatar
negative camber ftw
Old 01-18-09, 11:21 AM
nokcy21
nokcy21's Avatar
thanks guys!!! i guess i have to go for a coilovers or save up for air . so it will slammed to the ground
Old 01-18-09, 01:28 PM
chrispy
chrispy's Avatar
Wait, you were afraid of negative camber wear on your tires but now you want to get coilovers to go lower?
Old 01-18-09, 01:33 PM
VIS250P
VIS250P's Avatar
What a weired moment
Old 01-18-09, 01:36 PM
AYEmike
AYEmike's Avatar
guess you guys finally convinced him negative camber is a good thing for vipstyle
Old 01-18-09, 03:39 PM
GSteg
GSteg's Avatar
I wish this was true, but it only applies to those with coilovers. Spring users will end up with more negative camber in the front.
<----spring user
Old 01-18-09, 08:03 PM
Debonair
iModerate
Debonair's Avatar
<----spring user
How much negative camber are we talking about? How much lower will the RCA's make it go in the front?
Old 01-18-09, 08:21 PM
nokcy21
nokcy21's Avatar
i was convinced that more negative camber the better for the VIP look. i got -2.85 camber in the front. but gonna change my wheels to get a better offset. cause now its a bit conservative +35. palnning to go +24 so i can still tuck my tires when i get some coilovers.
Quick Reply: drop with tanabe, too much negatice camber
