Squeaking noise from front end
I would check two things. First lubricate the piston on the coil overs with lithium grease, something like white lighting or some other brand. If that doesn't take care of the problem I'd move to the front sway bar bushings. If they're OEM they need to be replaced, if they're aftermarket like the Daizen's they need to be re-greased and you should be OK. As an FYI, I have to lubricate the rears on my Tein's twice a year to get rid of noises.
Thanks for the reply. First, I do not have coil overs. My set up is just lowering springs on the stock shocks. But as for sway bar bushings they are still OEM so I will check out that out. Thanks for your help!
